10-06-2009, 06:14 PM | #1 |
VIN on the frame?
Where would the VIN be on the frame of the C10?
I have a 80 cab but I want to make sure it's the matching frame for it (parts truck being rebuilt) Thanks
Tim Baillie Installer/Designer/Fabricator Trick Factory Customs Company - www.trickfactory.com Personal - www.hzemall.com Instagram - @hzemall |
10-06-2009, 06:16 PM | #2 |
6.0 powered square
Re: VIN on the frame?
its on the driver side by the transmission cross member
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 10-06-2009 at 06:17 PM. |
10-06-2009, 06:17 PM | #3 |
Inner or outter of the frame ?
10-06-2009, 06:19 PM | #4 |
6.0 powered square
outer
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
10-06-2009, 06:19 PM | #5 |
10-06-2009, 07:09 PM | #6 |
I would have said passenger side, top of the rail under the cab. That's where we put 'em in Flint. Where was your truck built, do you know? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-06-2009 at 07:10 PM. |
10-06-2009, 07:11 PM | #7 | |
The frame has dual tanks, but the cab isn't wired for it.
10-06-2009, 07:17 PM | #8 |
6.0 powered square
mine was built in st Louis
10-06-2009, 07:18 PM | #9 |
Dually Pride
Keith, do you know where the location is on a Canadian '74? thanks!
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
10-06-2009, 07:22 PM | #10 | |
At any rate - I believe it should be on the top of the rail, because of the way the "stamp" pressed the numbers in. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-06-2009 at 07:23 PM. |
10-06-2009, 07:23 PM | #11 |
Thanks, Aaron.
Is it on the top of the rail, or when you say "outside" does that mean you can view it from beside the truck? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-06-2009 at 07:24 PM. |
10-06-2009, 07:25 PM | #12 | |
Assuming it was built in either Oshawa or Flint I'd say top of the rail, pass side, under the cab. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-06-2009, 07:26 PM | #13 | |
10-06-2009, 07:27 PM | #14 |
Mine on my 78 is actually stamped twice. Is that normal? It is stamped once passenger side top rail under cab and once again about 10 inches towards the rear. Truck was built in Canada if it makes a difference.
10-06-2009, 07:28 PM | #15 |
6.0 powered square
if I had a driver side fuel take, most of the numbers would be hidden
10-06-2009, 08:05 PM | #16 |
Curmudgeon of Poor Means
I have an 82 C20 built in StLouis; it's stamped on the driver's side under the cab on top of the rail (you wouldn't be able to see it with the cab in place) and if memory serves it's stamped again on the same rail somewhat to the rear, but I'm a little foggy on that one. If it matters I can look at it tomorrow in the sunlight.
Travis |
10-06-2009, 08:08 PM | #17 |
For what it's worth, it's only the last 8 of the VIN; I assume that was S.O.P. (Kieth?)
Travis |
10-06-2009, 10:05 PM | #18 |
So it isn't going to tell me anything.....
10-06-2009, 10:55 PM | #19 |
It shouldn't be a problem since you're only trying to verify if the frame & cab match...the first 9 digits of the vin tell you it's made in USA, GM, Chevrolet, tonnage, 2 or 4 doors, 2 or 4 wheel drive and which engine it shipped with...the last 8 tell you year, plant it was built in, and the last 6 are unique to your truck. You already know everything the first 9 tell you.
Make sense, or did I confuse you? All the shop manuals have a chart that explains what the various letters/numbers in the VIN mean. I've seen the same chart in the front of the LMC catalog too. I'm assuming we're talking about a 1981-up vehicle; 1980 and back used a different system. In 1981 all cars built everywhere adopted a 17 digit VIN system designed to standardize how they were interpreted. The first digit, for example, tells you the country of origin...1 is USA, for example, J is japan, W is Germany...so I'm assuming yours starts off with a 1. Then a G for GM. There oughta be a chart online somewhere, but I didn't find a good one with a quick Google search. But surely you have an LMC catalog? Some of the others might have it too. Sorry for the long post; hope I made sense. If not, just ask; I'll keep looking for a better site to link to. |
10-06-2009, 11:09 PM | #20 |
Found a good site; GM no less. Click on the model year of your truck and it'll give you a pdf file of how to interpret each letter/number of your VIN...
http://service.gm.com/dealerworld/vincards/ Travis |
10-06-2009, 11:11 PM | #21 |
Cool, I just need to find it on the frame
10-07-2009, 07:11 AM | #22 | |
Sounds right. Twice on the same truck is within reason, too. K
