Old 01-16-2003, 04:42 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Lowering springs for C/10 & C/20????
I want to lower my 1970 C20 about 3 inces in the front with springs...I was wondering if I can use lowering springs for a C10 in my C20? Will they fit and if so will it sofen up the ride a little? Also I want to install a flip kit for the rear and was wondering if a flip kit for 73 and up trucks would work? Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 01-16-2003, 05:34 PM   #2
special70gmc
special70gmc's Avatar
the 1/2 ton springs are the same and will fit perfict. not sure bout the flip?
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 01-17-2003, 02:59 AM   #3
HotRod929
HotRod929's Avatar
Thanks for the help. Anyone know weather the flip kit will work?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 01-17-2003, 11:54 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm asuming you have leaf springs out back?
Flag down crazy longhorn or PM him...I think he did this before ripping out his 3/4 ton stuff.
Old 01-17-2003, 06:35 PM   #5
crazy longhorn
Fabricate till you "puke"
The rear drop on my longhorn was done at the same time that the suspension was changed to 1/2ton parts. I have tossed the helper leaf, & 3 bottom leafs. The 12 bolt axle was then set up with direct connection spring pads, & flipped over the spring. U bolts & brackets are a 67 ford truck item. After the flip, the axle set too low, & the spring perches were moved down on the frame 1 1/4" to raise the truck back up a bit. The rear hangers have an added 3x3x 3/16 angle bracket to keep them from flexing,& a set of slapper bars were added to control wheel hop. I have roughly a 5" drop at the rear, no C notch,& 2 3/4" clearance tween the axle & frame. I have never bottomed the axle on the frame, but for hauling, you will be very limited. On front, you can run a 3 " drop spring, but most guys will tend to agree that a 2" spring is about max if you want to keep front geometry as it should be. My truck was done several years ago, when there just werent any bolt on pcs available......not even springs. The fronts were a new set (lightest available),& have 1 full ring cut off. along with the shorter springs, I have trimmed the bump stops on the lower a arms,& use a traction bar "snubber"for bump stops on both the upper & lower arms. i have also fabbed brackets to relocate the top end of the shocks, & run stock lenght Monroe gas shocks. You can opt for shorter shocks, or Turner Enterprises sells a shock relocator for the fronts for about$45. Good luck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
