Old 10-06-2009, 10:42 PM   #1
Patriot
2WD frame
I found a 2WD frame to replace my torched up 4WD 1 Ton frame.
I was wondering if you guys think I should buy this frame and just switch the spring perches over to the new frame?
Is there any difference in these frames other than no perches for the Dana 60?
Thanks fellas.
Patriot is offline   Reply With Quote
Old 10-06-2009, 10:51 PM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: 2WD frame
well from what I understand. you will lose a bit of your one ton capability as they are much taller then 1/2 tons. but you probably knew that?
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 10-06-2009, 10:54 PM   #3
Patriot
Re: 2WD frame
I'm sorry I forgot to say it was a 1 ton also. my friend just wanted to pull the 454 first and sell me the rest of the truck.
Old 10-06-2009, 11:12 PM   #4
79gmcc15
79gmcc15's Avatar
Re: 2WD frame
Ah, and I also assumed it was a half ton for some reason LOL
RIP ELJAY
Old 10-06-2009, 11:16 PM   #5
Patriot
Re: 2WD frame
Its all good!!
Old 10-07-2009, 05:41 AM   #6
ghettoluxury
ghettoluxury's Avatar
Re: 2WD frame
as long as you have both 1 ton frames you should be able to piece together what you need. I belive that all the holes for the 4x4 stuff are already in the 2wd frame.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
