Old 10-07-2009, 01:01 AM   #1
yellowGT
yellowGT's Avatar
Need help with Dually question
I think im going to purchase a dually crew cab but apparently it used to have a diesel engine before. Now my question is...What would I have to change in it to make it work on pump gas? Im thinking about throwing a big block in it and later on bagging it with big rig wheels. All help appreciated.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 10-07-2009, 01:10 AM   #2
2tons of fun
Re: Need help with Dually question
install the big block.
2tons of fun is offline   Reply With Quote
Old 10-07-2009, 01:27 AM   #3
yellowGT
yellowGT's Avatar
I got that down. Sending unit or anything else? Just wondering.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 10-07-2009, 02:38 PM   #4
Storm Chaser
Storm Chaser's Avatar
You will need to change the sending units in the gas tank. I imagine you will have to do some rerouting of the fuel line in the engine compartment. Starter and alternator shouldn't be a problem, since both engines used them, but you will need power to the distributor, which you can get from the injector pump wire if I recall. Other than that, it should be straightforward like any other engine swap.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 10-07-2009, 03:15 PM   #5
sailed2japan
Jonny
sailed2japan's Avatar
Just put a Cummins in it, screw all that Big Block crap
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 10-07-2009, 03:45 PM   #6
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Or be a little different...put in a Duramax and Allison it the thing.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 10-07-2009, 09:13 PM   #7
dropd80s
dropd80s's Avatar
Are you sure it used to be a diesel? I had a local guy buy a 79 dually and some mechanic told him it used to be a diesel cause it had two batteries and the hydroboost
dropd80s is offline   Reply With Quote
Old 10-08-2009, 10:12 AM   #8
yellowGT
yellowGT's Avatar
I wont get to see the truck til tomorrow or saturday so not totally sure if it was a diesel. I do remember the guy telling me that the truck had a 6.2 diesel engine that he took out so it might of had one. I guess it shouldnt be a big problem doing a swap just wanted to make sure it wouldnt make me pull hair out. I thought about putting a 6.0 in it but I havent ran into one yet so we'll see.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 10-08-2009, 08:03 PM   #9
rare86
Extended cab fanatic
rare86's Avatar
One problem may be the bell housing on the transmission. SOme used the BOP bolt pattern, but I dont remember for sure if the 6.2 did. What year is it?
I dont know why youd have to change the sending units is the fuel tank unless its got the intank fuel pumps.(not arguing woth ya strom chaser, hoping to learn something) You will have to get all of the desiel out of the tanks and line you can, and I think the torque convertor is different than a gas one. your accessories will be the biggest pain to mount. If you have all of the brackets for you engine, then your set. The deisel radiator should work without any problems. Like I say tho, the year of the truck will make some difference.
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
Old 10-09-2009, 02:26 PM   #10
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
The tranny should be a Chevy pattern (the 5.7 diesel used the BOP pattern), but I've been told that the torque converter is different between gas and diesel transmissions. I'm using a 400 turbo from a 6.2 truck in my '77.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 10-09-2009, 06:26 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, the diesel torque converter is actually a lower stall speed than a gas application used. Just swap the converter for a gas truck version.
I agree about the sending units too. Just get the tank clean and the lines blown out of old diesel and reuse it all. I did this swap about 15 years ago and that's what I did at the time.
Old 10-11-2009, 12:58 PM   #12
Storm Chaser
The 6.2/6.5 engines used the same bell pattern as the sbc, and if I remember right, even the motor mounts will work.
Well, the pickup should work, but the sock will be different because diesel fuel is thicker- using the diesel sock will let all kinds of junk through it when used in a gas application. The reason I say to change the pickup is because I'm pretty sure the gas sock won't fit on the diesel pickup tube.
1988 R2500 Crew Cab
Future plans-
Old 10-11-2009, 03:23 PM   #13
rare86
rare86's Avatar
Ok I see , thanks Storm Chaser. Id still use the same setup because I prefer to have an inline filter just before the fuel pump anyway. Its easier than dropping the tanks. Just my opinion.
Old 10-11-2009, 03:29 PM   #14
nekkidhillbilly
give it to me and ill put a dmax in it
nekkidhillbilly is offline   Reply With Quote
Old 10-12-2009, 09:11 AM   #15
Storm Chaser
I hear yoa rare86- I still have to drop TWO tanks to change from fuel injection to carb. NOT looking forward to it.
1988 R2500 Crew Cab
Future plans-
Old 10-13-2009, 08:00 AM   #16
rare86
rare86's Avatar
Im planning of going the other direction, from carb to FI. I think it'll be easier to take the bed off. Undo the fillers ( have to anyway), 8 bed bolts, one electrical plug and lift.
Old 10-13-2009, 12:11 PM   #17
Storm Chaser
Normally that would be the easier way, but my truck is at my brother in law's house, in town with strict ordinances for 'disassembled vehicles.' His neighbor would call on us as soon as the bed left the truck. Plus, the bed is entirely full of parts, which would have to get piled in the yard. Unless I can find somewhere else to do it, I have to drop the tanks.
1988 R2500 Crew Cab
Future plans-
