Old 10-07-2009, 02:18 PM   #1
Piece of Work
Cultural Infidel
Piece of Work's Avatar
5 Speed swap
Has anyone gone from a TH350/ Th400 to a 5 speed? If so what tranny did you use and how much fabbing is involved? Is there direct bolt in for this swap?
-Mark
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 10-07-2009, 02:46 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 5 Speed swap
I used a TKO-500 and switched from a TH400. No 'bolt-ins' going from auto to manual that I know of. I had to move the crossmember, change driveshaft length, fab up clutch pedal/master cylinder (I used a hydraulic t.o. bearing), and cut a hole for the shifter. The only thing I was able to reuse was the tranny mount itself here are a couple pics
http://67-72chevytrucks.com/vboard/s...d.php?t=364326
I've posted pics in other threads too, you may try a search. Any specific questions, just ask!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-07-2009, 04:23 PM   #3
Piece of Work
Cultural Infidel
Re: 5 Speed swap
Originally Posted by BossHogg69 View Post
I used a TKO-500
Did you see any improvment in MPG?
posted via La-Z-Boy
-Mark
Old 10-07-2009, 05:15 PM   #4
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: 5 Speed swap
NV3500 is also a good choice. Same steps as above though.
texanidiot25 is offline   Reply With Quote
Old 10-07-2009, 06:12 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 5 Speed swap
I'm really not trying to be a smart ass, but I have a 454 and a leadfoot, so MPG was never my intention for the swap. I did it for the fun factor and for the ability to let her 'stretch her legs' on the highway. In fact, I just pulled the 454 out for a rebuild aiming for 530hp... But yes, if driven like a normal adult, the .68 OD will offer decent mpg over a non-OD trans, even with 3.73's. I'm sure I could get 15-16 on the highway if I didn't hammer on it so much. I was getting 12-13 before, but that was at 55mph, not 70-75 like I can cruise now.
BUT- my swap cost right around $2200 by the time it was all said and done, and you can buy a lot of gas for that, so it may be time to get out your calculator and see if it's worth it in the end. Or you can buy a used 4cyl car for $2200 and get 30mpg all day...
In my opinion, an NV3500 isn't worth the trouble. some say they'll live behind a stock motor, and it might if you drive like an old woman. I had one in a '92 ecsb 1/2 ton with a slightly warmed over tbi 350 and they would'nt hold up. That was what I got the TKO for originally, but ended up selling the truck and putting the TKO in my '69. You can pick up a used one for around 400-500bucks all day, but again, you still some fabbing ahead of you.
Is an overdrive automatic not something you want? Do you have a budget in mind?
Adam
Old 10-07-2009, 10:43 PM   #6
texanidiot25
Eat My Rust
Re: 5 Speed swap
I'm sorry, I meant the 4500.
I keep thinking 3500 since that's the designation for the 3/4 tons.
Old 10-08-2009, 03:50 AM   #7
2tons of fun
Re: 5 Speed swap
keep thinking because 3500 is the des for a 1 ton.
you would be better off with a 3500 or 3550 than a 4500.
4500 are less common in chevy, very big and slow shifting, its a truck tranny not a go fast and speeder tranny.
a world class t5 would do ok, you would need to buy the clutch stuff in peices because you will need a 26 spilne disc.
2tons of fun is offline   Reply With Quote
Old 10-08-2009, 01:24 PM   #8
MrBlue
MrBlue's Avatar
Re: 5 Speed swap
BossHogg69,
Where does one find a used TKO for $400-500 all day long?
I've been watching several different sites and have only been able to locate new for +$2200!
MrBlue
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 10-08-2009, 02:01 PM   #9
Jim_PA
Re: 5 Speed swap
Originally Posted by MrBlue View Post
BossHogg69,
MrBlue
They are talking about NV3500's for $4-500, not TKO's.
Jim_PA is offline   Reply With Quote
Old 10-08-2009, 05:13 PM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 5 Speed swap
Thanks Jim_PA
I WISH I could've found a used TKO!!! But if you want a t56, those are fairly common on the used market.
.... and that was pretty funny 2tons
Adam
Old 10-08-2009, 05:38 PM   #11
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: 5 Speed swap
I swapped a TH350 to a Richmond 5-speed. Used factory clutch/bell housing/linkages. had to make my own shift handle.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 10-08-2009, 05:44 PM   #12
Mayo
Cool Truck
Mayo's Avatar
Re: 5 Speed swap
I swapped to a T-5 out of an 83 Camaro. I haven't had any problems with it.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 10-08-2009, 08:47 PM   #13
clinebarger
Re: 5 Speed swap
I can tear up a T-5 with a V6 mustang T56 is the way to go.
clinebarger is offline   Reply With Quote
Old 10-08-2009, 09:06 PM   #14
texanidiot25
Eat My Rust
Re: 5 Speed swap
My bad (again)..
