Old 10-08-2009, 01:02 AM   #1
Jbham88
Jbham88's Avatar
69 GMC to 77 K5 frame swap??
I have a 69 gmc swb, i have found a 77 k5 blazer for 1500 thats in decient shape. Just wanted to know if it will fit and how much of a hassel it is. Or if anyone has done this Thanks
1986 GMC 4x4
Jbham88 is offline   Reply With Quote
Old 10-08-2009, 03:42 AM   #2
OARNGESI
OARNGESI's Avatar
Re: 69 GMC to 77 K5 frame swap??
The frame on the k5 is shorter so youll have to cut down the bed like a foot infront of the wheels and build a body lift
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-08-2009, 10:59 AM   #3
Jbham88
Jbham88's Avatar
Thanks i dont want to cut my body at all
1986 GMC 4x4
Old 10-08-2009, 12:30 PM   #4
GruntMoanCough
GruntMoanCough's Avatar
Yes, I've done this a few times. You can lengthen the Blazer frame, but the body will sit a couple of inches higher due to how the bed sits on the frame.
The rad support mounts need to be moved back, the front cab mounts are close, and I forget off hand what needs doing with the rear cab mounts.
Steering column length needs to be changed.
I believe that there are threads on this topic, maybe in the projects and builds section.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 10-08-2009, 01:42 PM   #5
Jbham88
Jbham88's Avatar
well I knew the body mounts were going to have to be changed but i was just trying to get the 5 lug setup and disc brakes and maybe save some money along with the 350 and sell my 327
1986 GMC 4x4
