10-08-2009, 04:16 PM | #1 |
Storing A Truck
I have to store my 71 LWB for 3-4 years, (going overseas for another long tour)does anyone have any suggestions on what I should do to my truck prior to slamming the storage unit door? Stabil wont last that long so a complete fuel tank drain is in order I imagine, should I drain the antifreeze too? What about engine oil other fluids, etc? Put it up on jackstands? I was just trying to make as little work as possible for myself when I get back and get to use it again.
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
10-08-2009, 05:06 PM | #2 |
Re: Storing A Truck
This is what I would do:
Put synthetic oil in the motor.... Put the truck on jackstands..... Drain all the fuel......... Put a cover on it........ Make sure your insurance is paid in full just if something happens....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-08-2009, 05:16 PM | #3 |
Redefining LowBudget
Re: Storing A Truck
I think if I was to store it that long I would fog the motor like it was a boat motor this will coat the holes with a layer of oil to keep them clean might even crack the valve cover and loosen up the rockers to get the load off springs
take out the battery get a bag of dry pellets (the stuff they put in your pill bottles only bigger) steel wool the tail pipe speedy dry piles in the corners plastic sheet on the floor |
10-08-2009, 05:41 PM | #4 |
Re: Storing A Truck
Drain the fuel
Make sure the coolant is full with proper antifreeze Disconnect the battery Put the truck up on stands Let all but 15lbs or so out of the tires and smear some silicone on the sidewalls. Hit your interior with something that will last a while like Meguiars. Close it up tight and put a cover over it. You may end up having to replace some items like the master cylinder, shocks, or anything with a rubber seal in it if this isn't stored in a "climate controlled" enviroment and any of these parts have some age on them. You will figure that out though after you start driving it again. You don't need to mess with the oil until you get back. I'd change it before you drive it though. |
10-08-2009, 06:28 PM | #5 |
Re: Storing A Truck
i'd put a really heavy coat of wax on the truck in addition to wats already been listed
10-08-2009, 06:43 PM | #6 |
Re: Storing A Truck
Hermetically seal it in a large plastic bag. Or, let someone you trust keep it until you get back on the condition that he or she drives it and maintains it.
10-08-2009, 06:57 PM | #7 |
I am a Referee of life.
Re: Storing A Truck
Dryer sheets or something like them.Even good storage places have a few rats/mice and you want to keep them out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-08-2009, 08:35 PM | #8 |
Re: Storing A Truck
Thanks all, as usual, terrific responses! I would have never thought of the steel wool or letting pressure off the valve springs.
mclairmo I'd loan out my only daughter before I'd loan out my truck for four years! J/K
10-08-2009, 08:46 PM | #9 |
Re: Storing A Truck
10-08-2009, 09:16 PM | #10 |
Eat My Rust
Re: Storing A Truck
My neighbor tells me to spray WD40 down the intake with the truck revved up until it stalls. Helps prevent inner rust? Who knows if there is merit to it, but that was his suggestion.
10-08-2009, 10:17 PM | #11 |
70 Chevrolet=Obsession
Re: Storing A Truck
The one suggestion that I think would be most important would be to drain the float bowls in the carb. That gas goes bad too. I would also grease all my suspension fittings before storing just for good measure.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
10-08-2009, 11:20 PM | #12 |
Re: Storing A Truck
Actually that's a bad idea. WD40 will scrub the cylinders and rings clean and makes them rust faster. You need to use a fogging oil if you're going to do it. You can pick some up at a boat shop.
10-08-2009, 11:24 PM | #13 |
Re: Storing A Truck
10-08-2009, 11:26 PM | #14 |
its all about the +6 inches
Re: Storing A Truck
if you put it on jackstands, do it where the suspention is loaded, not unloaded.
I would do the synthetic oil BEFORE storage tape or steel wool over the tail pipe AND over the snorkle on the air filter leave antifreeze in it moth balls on top of the engine, in the cab, under the truck on the floor, on the frame rails if it has nace paint, cover the whole thing with a nice soft car cover, or moving blankets Sta-bil will work for 4 years, seen it done myself. personally I would fill it up and put the sta bil in there, then dump it all out before starting. The fuel will displace the humidity in the air and prevent rust. dont spray WD in the motor. |
10-08-2009, 11:30 PM | #15 |
Re: Storing A Truck
These are all great ideas. I'd never have thought of half of them. The only thing I would add is to make a list of everything that was done prior to your daparture and post in a very conspicuous place. Perhaps attatched to the steering wheel?
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
10-08-2009, 11:32 PM | #16 |
Re: Storing A Truck
Oh, one more thing. Take your wipers off.
If you're going to fill the tank and add the stabil then make sure you drive it around a little bit before you park it. Otherwise the fuel in the lines and carb will not be stabilized. Last edited by highperf4x4; 10-08-2009 at 11:35 PM. |
10-09-2009, 12:29 AM | #17 |
Eat My Rust
Re: Storing A Truck
10-09-2009, 12:31 AM | #18 |
Re: Storing A Truck
10-09-2009, 06:16 AM | #19 |
Re: Storing A Truck
Yeah, I feel the same about my 67 Camaro but my truck is a driver. I would not mind loaning my 68 C10 to someone I really trust, which happens to be only my dad.
10-09-2009, 12:47 PM | #20 | |
Re: Storing A Truck
This is how it would have happened..... Sometime in 2014- hmmmm why wont this damn thing start (no batt, gas,) Why does it smell like mothballs in here? (they are everwhere) Whats that sticking out of the tailpipe? (steelwool) Why does my motoer have so much valvetrain noise? (no oil) Why wont my truck go (its on Jackstands) Anyway you all are great, I really wanted to come back to ID after my year in Korea, but the Family really wanted to go see Europe before I retire, so UK it is, lots of board members from there, maybe I Ought to bring it along! instead of my Suburban, I wonder if they would let me haul kids in the back? Doubtful....
10-09-2009, 01:25 PM | #21 |
Re: Storing A Truck
Might want to see about some moisture absorbant stuff for the cab. Get it at an RV supply place.
10-09-2009, 01:27 PM | #22 |
Re: Storing A Truck
Corona bottles in the tail pipes!
Keep the mice out
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
10-09-2009, 01:52 PM | #23 |
Re: Storing A Truck
buy a bag of bbq bouquets, regular type, put any where you want no moisture, as they suck up moisture. Try em in your tool box to, if it's stored or used in a place where moisture is...and here in washington state we have a little moisture.
