10-08-2009, 07:36 PM | #1 |
Help! Please!
okay guys here's the deal... i'm having a few problems that i cant seem to permanently fix
#1) i have recently had the transmission rebuilt ( for the second time in two years... yea go figure all i can say is i wouldn't take my neighbors car to him) anyways since i've gotten the truck back now my reverse lights only come on in neutral and wont come on in reverse and i am wondering if this happens to be the switch, short or linkage problem #2) my truck also likes to eat blinker switches in its spare time this is also the second blinker switch that i have gone through and wonder what a permanent solution to the problem might be because i'm tired of having to always pull the steering wheel to replace the cam... any help on either of these problems would be very helpful... thanks ahead of time ill also include a picture of my truck so you guys can see my fairly recent project that i have acquired its a 350/350 71 with very little rust
Ryan, _______________________________________________ 1971 C10 350/TH350 |
10-08-2009, 07:42 PM | #2 |
What?
Re: Help! Please!
Does it have a trailer hitch? If it does, check to see how the trailer light plug was put in. That's usually the begining of a lot of tail light issues.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
10-08-2009, 07:45 PM | #3 |
Re: Help! Please!
well when i got the truck about 3 years ago we put a new plug on it but it was still working after until the first time we had the transmission rebuilt then they would only come on while in neutral
10-08-2009, 07:52 PM | #4 |
Re: Help! Please!
easy enough to check the reverse switch with a multimeter to see where its erenergized and not// is this an auto tranny? if so the switch is near the floor on thesteering column
as far as the blinker do you mean the switch in the column under the steering wheel or the blinker in the fuse box// i'd check for bad connections and poor grounding of the lights
10-08-2009, 08:23 PM | #5 |
Re: Help! Please!
it is an auto trany and it the lights come on just not in reverse only when its in neutral
as for the blinker i was refering to the plastic cam under the steering column which usually cracks when it doesnt work i wont have a blinker for either side usually ends up being the drivers side however it would work when i would wiggle the turn signal lever and im wondering if there is an alternate route other than replacing those every time they break or wear the last one only lasted a month which is (knock on wood) about how long ive had this one...
