Old 10-08-2009, 10:25 PM   #1
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Leaf sprung to coil sprung...how difficult?
So I found a really good deal on a loaded and titled 72 C10 frame complete with brakes, suspension, rims, 12 bolt rear end, power steering from box to pump, new shocks, clean and straight ready to roll, unfortunately it is leaf sprung and Bessie is coil. How hard would it be to modify Bessie's 3/4 ton coil spring frame to accept the C10 suspension components mentioned above?
screamin_c10 is offline   Reply With Quote
Old 10-08-2009, 11:05 PM   #2
Puropedo
Re: Leaf sprung to coil sprung...how difficult?
I dont think it is really difficult, boardmember Gringoloco have done it, but on a 1/2 ton frame, it is basicly the same deal, you will have to swap the center crossmember and do a little welding or drilling for the panhard bar, now for the coils you will have to build some sort of base (since leaf spring frames didnt came with them, or if I were you, I would install heavy duty air bags for a softer ride and heavier load capacity, just my 2 centavos..
Puropedo is offline   Reply With Quote
Old 10-08-2009, 11:17 PM   #3
2tons of fun
why not just swap the entire frame?
2tons of fun is offline   Reply With Quote
Old 10-09-2009, 12:34 AM   #4
highperf4x4
So are you wanting to use the leaf springs or the coils?
highperf4x4 is offline   Reply With Quote
Old 10-09-2009, 12:42 AM   #5
screamin_c10
I wanted to use the coil suspension on the 12 bolt. I guess I would have to weld perches on the 12 bolt rear for the trailing arms and fab up a panhard bar mount on the pumpkin.... Probably more work than its worth...
Old 10-09-2009, 01:01 AM   #6
highperf4x4
Then I would take this suggestion with the air bags.........
Old 10-09-2009, 07:05 AM   #7
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Are you going to eventually lower it? I did a swap from leafs to coils and yes I had to get perches for the axle but as far as the panhard bar mount on the axle, I just went with a Super Trac Bar that goes from the d/s frame to the p/s trailing arm u-bolt. I purchased both the Super Trac Bar and Axle Perches from ECE. There were other brackets I had to get from donor trucks but IMO, the swap was worth it for me. I did think of just swapping frames from leafs to coils but here in South Florida the availability of excess frames or even "Our Trucks" and their parts are very hard to come by. My 69' Stepside currently has a 3/6 drop but it will eventually be bagged.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 10-09-2009, 11:49 AM   #8
71tahoe
71tahoe's Avatar
on the ECE perches and super track bar. Get new u-bolts too.
71tahoe is offline   Reply With Quote
Old 10-09-2009, 01:43 PM   #9
67sss
67sss's Avatar
why would a 72 c 10 have a 3/4 ton reared? the front is already a 1/2t suspension.
67sss is offline   Reply With Quote
Old 10-09-2009, 02:02 PM   #10
screamin_c10
You read the question wrong. I want to put a '72 1/2 ton 12 bolt rear end and front disks under my '67 C20. The 1/2 ton has leaf springs, the C20 has coils. I want to keep the coils....
Old 10-09-2009, 02:08 PM   #11
screamin_c10
@ Myoldchevytruck
What other brackets are needed for the conversion? Were the ECE perches easy enough to install. I can get this frame as shown for ~ $250 so I can justify throwing a little money at it. How much did the conversion cost, ballpark?
Old 10-09-2009, 02:34 PM   #12
myoldchevytruck
They come with the Super Trac Bar kit.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 10-09-2009, 02:56 PM   #13
myoldchevytruck
[QUOTE=screamin_c10;3560051]@ Myoldchevytruck
[/QUOTE
Required brackets would include the 2 brackets for the center cross member. These attach the trailing arms to the cross member. I also replaced my trailing arms bushings while they were out and the hardware I used was grade 8 nuts, bolts and washers. There were 8 of those. The other bracket is the bracket located on the drivers side of the frame right behind the axle. This bracket is for the Super Trac Bar to bolt to on the frame side. The other side goes to the Passenger Side Trailing Arm. It bolts in with the Supplied New U-Bolts. For the frame bracket, I again used grade 8 nuts, bolts and washers. For this bracket, I had to drill holes. These are Brackets I bought off of members on the board from old frames and such. If I remember right they were like $20 for the frame bracket and $20 for the cross member brackets plus the shipping. As far as the axle perches, they were not hard to line up and weld at all. Check with ECE for current prices on the perches and the Super Trac Bar. Also check out their site. They used to have a rolling chassis with half leaf and half coil. You'll see the brackets I'm talking about. If you want to ask more questions, pm your number to me. I think it was well worth the change over. Good Luck
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 10-09-2009, 05:57 PM   #14
screamin_c10
So other than the trailing arm crossmember and a couple of brackets the frames are the same between coil and leaf sprung.....sweet, looks like I'll have an extra frame laying around for another project....
Old 10-09-2009, 08:49 PM   #15
myoldchevytruck
your leaf spring frame should have the cross member already. It's the cross member brackets you'll have to get.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
