10-08-2009, 10:52 PM | #1 |
New Member
CTrow's Truck
So here's the history. I got this when I was 15 (32 now) and it was supposed to be my sweet 16 truck but Dad got carried away. It got too nice and Mom put a stop to the money spent. Well, high school came and went, college came and went, the first home came and is still here. Basically life I guess. I finally got to a point where I could pick back up and get this thing finished.
Life started out as a 70' LWB but we cut it down, put 68' nose one, and put a step side bed on. It was oiginally painted 90' S10 green. 305 Tuned port. Full Street and Performance billet engine accessories. Plans are to switch out the step side for a fleet side, repaint it black, keep the 305 for now until I can afford a LS1. The main goal now is to get it painted and get it driveable. I may not have the interior exactly like I want but at least I can take it down the road. Suspension will be a cool ride air in front, with air over leaf in the rear. Later I may look into a drop member with full shock waves but again, I want to get it driveable. It will be a fun project and be a nice driver. Not daily but often enough. And remember, blacks not a color.....It's a lifestyle! Last edited by ctrow; 12-16-2009 at 11:46 PM. |
10-08-2009, 10:54 PM | #2 |
New Member
Door panels
Door panels. The tweed is a bit outdated but will work for now.
10-08-2009, 11:04 PM | #3 |
New Member
Re: CTrow's Truck
Pictures of the motor.
I'm painting the block/intake a silver that will match the wheels. Intake, runners, billet accessories will be chromed. Compressor/Alternator/PS pump will also be silver. I ended up having to buy a couple of new idler brackets as S&P changed the design. I also changed to a Type III PS pump which tucks in closer to the motor. Exhaust manifolds are ram horns from Speedway. I'll smooth them out and get them coated. |
10-08-2009, 11:07 PM | #4 |
New Member
Re: CTrow's Truck
Got a new bed floor from Southern Kenntucky.
10-08-2009, 11:08 PM | #5 |
New Member
Re: CTrow's Truck
Bed pictures
10-08-2009, 11:24 PM | #6 |
Re: CTrow's Truck
Looks very nice. Personally I hate to see the step side go!
Paint looked good, did it need new paint or are you just not digging the color anymore? |
10-08-2009, 11:27 PM | #7 |
New Member
Re: CTrow's Truck
Wheels
Coys Rear: 20X10" 295/40/20 Coys Front: 20X8.5" 245/40/20 Tires are BFG KDW |
10-08-2009, 11:33 PM | #8 |
New Member
Re: CTrow's Truck
Making the C notch, building the rear shock mount brackets, boxing the rear of the frame.
10-08-2009, 11:38 PM | #9 |
New Member
Re: CTrow's Truck
Radiator cover
I wanted something that completely covered the radiator as well as the electric fans. I'm also using it to mount the electric fans. It's probably too heavy duty but the metal yard that day had either too light of sheet metal or this. I'd rather it be too strong than flimsy. When it's all mounted you won't see any fasteners so it should make it clean. Last edited by ctrow; 10-08-2009 at 11:43 PM. |
10-08-2009, 11:41 PM | #10 | |
New Member
Re: CTrow's Truck
The biggest part of the bed I hated was there was no way to run the size of tire I wanted without cutting the inside of the bedsides. And with the ribs that ran horizontally it wouldn't have looked right without a lot of work. |
10-08-2009, 11:48 PM | #11 |
New Member
Re: CTrow's Truck
Dash work.
10-08-2009, 11:50 PM | #12 |
New Member
Re: CTrow's Truck
Off to paint. You can see we're a 67-68' C10 family.
10-08-2009, 11:53 PM | #13 |
New Member
Re: CTrow's Truck
Rolling chassis pictures.
10-08-2009, 11:56 PM | #14 |
New Member
Re: CTrow's Truck
Paint progress as of 10/8.
10-09-2009, 12:15 AM | #15 |
VA72C10
Re: CTrow's Truck
Very nice truck. You've done some great work. Nice fabrication on the rad cover!
Looking for a 67-72 swb or blazer project in or around VA. |
10-09-2009, 12:16 AM | #16 |
Re: CTrow's Truck
Looking real good!!!
10-09-2009, 12:57 AM | #17 |
New Member
Re: CTrow's Truck
Thanks!!!
10-09-2009, 11:09 PM | #18 |
Re: CTrow's Truck
Have you got any other pics of the flatbed truck and how the flatbed is attached.
10-10-2009, 09:54 PM | #19 |
Re: CTrow's Truck
NICE work, I love it! Thanks again for the bed and thank your dad for the color choice, I get compliments on the color everywhere I go.
Looking forward to see yours get done! |
10-10-2009, 11:40 PM | #20 |
chevy runs deep
Re: CTrow's Truck
Nice
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
10-10-2009, 11:43 PM | #21 |
Tot Roddin'
Re: CTrow's Truck
Subscribed!
Excellent progress on your "life-long" project. What BS did you get on the wheels? Can't wait to see what's next...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-11-2009, 09:34 PM | #22 |
New Member
Re: CTrow's Truck
This is all I have. Basically Dad made the bed decades ago. It used to be on a 65' C10. I want to say he shortened the frame but I'm not sure. The original version was built when I was probably 8 so not much I can remember about it. If you want more pics let me know. I'll take some the next time I'm down.
10-11-2009, 09:38 PM | #23 | |
New Member
Re: CTrow's Truck
I also have the CPP Modular spindles that bring in the wheels a little on each side so I think I run less backspacing than most. The front end is something out of a mid 80's truck. Easiest way to get 5 lug disc brakes. |
11-25-2009, 01:50 AM | #24 |
Re: CTrow's Truck
Any updates on the project?
11-25-2009, 08:56 AM | #25 |
67-72 parts collector,…
Re: CTrow's Truck
Nice build pics!
Subscribing,...
