6.0 powered square
I'm going to fiber glass my dash bezel smooth l, but I can't figure out how I want to lay out my gauges either in stock location or custom
![]() ![]() these are two I built in the past using diamond plate then sheet metal ![]() ![]() ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Re: dash help
I have thought of this before and am not sure if this is possible because of fitment and have no expierience with fiberglass. But maybe you could integrate the dash bezel (not the one you have, but making another out of fiberglass and other materials) into the dash with the fiberglass making it all one smooth peice. and you could place the guages where ever you think best.
Re: dash help
I think if you are going with a cool dash like that, why not think outside the box and move the gauges around too. Just take some time, look at different placements of them. From what you have done with the rest of the truck you will come up with something sick I'm sure!
It'd be alot cooler if you did
Re: dash help
Have you considered just doing a leather wrap on the dash? I think it looks a lot cleaner.
Re: dash help
You could move some of the smaller gauges to the space in the pad above the ash tray and angle them towards you.
I can still count my vehicles on two... wait three hands. |
6.0 powered square
Re: dash help
I thought of these
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 10-09-2009 at 02:07 PM. |
Re: dash help
What are your plans for the a/c controls if you moved things around?
6.0 powered square
Re: dash help
there is none just a off/low/high switch hidden at the bottom of the metal dash
