Old 10-09-2009, 11:59 AM   #1
wildwood
wildwood's Avatar
73-87 1ton axles on a 71 Blazer
I'm sure this has been covered somewhere in here, but I couldn't find it. Here goes: Will a Dana 60 front and 14 bolt rear from a 73-87 1ton (I don't know exactly what year) bolt directly to a 71 Blazer? Or do you have to move perches / modify stuff?
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 10-09-2009, 12:22 PM   #2
70 beast
Certified Hobbiest
70 beast's Avatar
Re: 73-87 1ton axles on a 71 Blazer
i believe the d60 will bolt in but the 14b might need to relocate the perches
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 10-09-2009, 04:09 PM   #3
Burt4x4
Burt4x4's Avatar
Yup, I did it to my 72
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-09-2009, 05:19 PM   #4
Blazer1970
Blazer1970's Avatar
Both axles will bolt in as long as the 14 bolt is from a K30. '73 - '87 one tons have a narrower spring spacing than the half and 3/4 tons making it the same as the '67 - '72 half and 3/4 tons. The rear shock mounts will have to be relocated.
Blazer1970 is offline   Reply With Quote
Old 10-09-2009, 06:20 PM   #5
Was`75 the first year K/30?
Old 10-09-2009, 09:48 PM   #6
1969 GMC
1969 GMC's Avatar
Late '76 or '77, depending on how picky you want to be. It was '75 with dodge, though...at least in terms of having the desireable D60 front.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-09-2009, 10:37 PM   #7
Dooley
Dooley's Avatar
GM intoduced the K30 to their lineup in 1977 model year. I bought one and have had at least one K30/Dana 60F equipped 4x4 in the drive ever since!
Dooley is offline   Reply With Quote
Old 10-11-2009, 02:50 PM   #8
wildwood
wildwood's Avatar
Thanks for the advice guys. I think these axles came in the same truck. I don't think any 3/4 tons had a 60 front (they were all D44HD as far as I know). So it's likely the 14bolt is from a 1ton. So then from the valuable info here, I will have to relocate the spring perches. I should be able to figure that out.
Old 10-12-2009, 06:41 AM   #9
Blazer1970
Blazer1970's Avatar
No, you will not have to relocate the spring perches, just the rear shock mounts.
Old 10-12-2009, 08:33 AM   #10
14-bolts were in all 3/4Ts after`72 as well.
The first K/30 I knew of was a`77 back then.I`m not sure where the`75 came from (big blocks in 4wd?).
