rally wheel spinners
does anybody know where i can get the spinners for a six lug rally wheel? i dont know if anybody makes them if not how about bowtie stickers i can only find the stickers to fit five lug
resident oilfield trash
Re: rally wheel spinners
Where did you find the 5 lug stickers
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
i have seen the 5 lug stickers on ebay i just searched chevy truck rally and found them
to make stickers go to any graphic arts signmaker a good one can make them for reasonable price // just bring a picture or drawing of what you want with measurements//spinner bars you might try wheet vintiques
its all about the +6 inches
spinnrs seem to be hit or miss items.
Seems every swap meet I've been to (admitedly, only a few) you could find spinners everywhere dirt cheap. If you go to e bay they are either junk, or quite expensive, and the few catalogs I've seen them in were rather expensive. |
You can use the same spinners that are used for 5-lug Ralleys. They will mount differently though. On 5-lug Ralleys, the spinner will slip over the snout of the cap (some require some clearancing/grinding).
For 6-lug Ralleys, the snout of the cap is a larger diameter than the spinner. You need 4 rear caps as these have the solid end vs. the open end front caps have because of the 4x4 front hubs. There is a centered hole under the sticker of the cap that will center the spinner. The spinner mounts flush to the end of the cap. You'll also find the hole sizes for the spinner & the center cap are different as well. You can use a rubber grommet in the hole on the 6-lug cap. When you thread the bolt through for the spinner, it will compress the rubber grommet enough to keep the bolt centered (enough so that it's not wobbling all over the place). Use Loc-Tite on the threads/hardware.
thanks for the help idid not know the same spinners would work on 6 and 5 lug
