Old 10-10-2009, 03:24 PM   #1
kvn1011
Kvn1011
kvn1011's Avatar
Thumbs up Could it be possible?? crossmember under 300.00 and lay frame on 22's 24's??
I just saw an episode of Trucks recently, and they had a weld together mustang II cross member kit, so i go to their website
http://www.welderseries.com/catalog/...hp?cPath=22_25
there i see the crossmembers prices $200.00 to $233.00,
so i emailed the company,
i got a response asking of what the track width is for the C10.
but i am not quite sure of the answer,
as i am making payments on my C10
and currently don't have the truck yet,
but hopefully another 2 months or so i will,
but from the looks of things,
I think an under 300.00 price may work with this company.
if anyone has the details
you can contact
Paul Horton
info@welderseries.com,
kvn1011 is offline   Reply With Quote
Old 10-10-2009, 03:32 PM   #2
Shane
Shane's Avatar
Re: Could it be possible?? crossmember under 300.00 and lay frame on 22's 24's??
no brakes ... no struts ... no spindles ... no rack ... not really a bargain once you add all these things up
Shane is offline   Reply With Quote
Old 10-10-2009, 03:47 PM   #3
kvn1011
Kvn1011
kvn1011's Avatar
I think it can be a bargain...
Old 10-10-2009, 03:54 PM   #4
Shane
Shane's Avatar
go for it. we like pics.
p.s. no a-arms either ...
Old 10-10-2009, 04:15 PM   #5
kvn1011
Kvn1011
kvn1011's Avatar
i will, and if it is worth me going Porterbuilt or SD, believe me i will!!
both great companies and products
but it also doesn't hurt to explore other options.
you are right!!
great observation!!
even though it is quite obvious
p.s
thank you for your input
Old 10-10-2009, 05:20 PM   #6
OARNGESI
OARNGESI's Avatar
Originally Posted by shane View Post
no brakes ... No struts ... No spindles ... No rack ... Not really a bargain once you add all these things up
does the dropmember or raised crossmember come with any of that for under 2k
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-10-2009, 05:26 PM   #7
Shane
Shane's Avatar
can't say since i've never purchased a dropmember / raised member ... nor did i endorse either over a MII.
i was just pointing out there there are more costs associated with a MII front-end conversion than just the crossmember.
Old 10-10-2009, 10:01 PM   #8
kvn1011
Kvn1011
kvn1011's Avatar
just kinda searching
but it could be possible to put something together
mcGaughy drop spindles 235.26 gcustoms.com
jegs mustang rack and pinion 229.99 junkyard (50.00)
**assuming one of the DIY mustang II kits that are made by paul hortons@ welderseries.com works out 220.00
or if a new version is created
i estimate 320.00 aprox w/shipping <just guessing>
**engine mounts 50.00 welderseries.com
monroe sensa trac shocks 31.87
tie rod ends 40.00
stock control arms
stock disc brakes
with everything added up it totals from 600.00 to 800.00 or so
depending on if you go with junkyard rack and pinion
((but nothing set in stone, just seeing what my future options are and what your opinions are))
bags would vary
could always z the frame but not sure i wanna go that route
Thanks all for your input
kev
