Old 10-10-2009, 06:55 PM   #1
fdbdw
fdbdw's Avatar
gas tank sock
Orderd a new sock for the sending unit, Ive never pulled the sending unit out so I dont know what to expect. Will it be obvious how to replace the sock once I get it out or is there any tricks to doing this
fdbdw is offline   Reply With Quote
Old 10-10-2009, 06:58 PM   #2
cdowns
cdowns's Avatar
Re: gas tank sock
just a hole in the middle that the tube slips into//if you have trouble figureing it out giveup
Old 10-10-2009, 10:07 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: gas tank sock
.. You are too cool Cliff... What he is trying to say is that it is really easy.
LockDoc
Leon
Old 10-11-2009, 09:07 AM   #4
fdbdw
fdbdw's Avatar
Re: gas tank sock
thats what I figured, thank you
Old 10-11-2009, 09:29 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Re: gas tank sock
Putting the sock on is not going to be a problem, but sometimes it may be stuck with varnish or debris. The real challenge is removing and especially replacing the assembly.
For safety reasons, be sure and use a brass drift or something that doesn't create a spark if you intend to tap it off and to reinstall. Pay particular attention how it comes off and be patient and work it a little at a time when reinstalling.
68gmsee is offline   Reply With Quote
