Old 10-10-2009, 10:42 PM   #1
mjensen
mjensen's Avatar
Rocker Panel Replacement
So a thought crossed my mind today. I'm going to replace my rocker panels, but my cab is off the frame. Is this something that can be done, or should I set the cab back on the frame with the fenders bolted up so that I can ensure that the rockers line up with the fenders?
TIA
Mike
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 10-10-2009, 11:36 PM   #2
mbgmike
Re: Rocker Panel Replacement
TIA
Mike
crap this is easy. No this is not hard to do. Rocker panels are not hard to do on any car or truck. We can show you how. It does not matter if off the frame or not
mbgmike is offline   Reply With Quote
Old 10-10-2009, 11:41 PM   #3
mjensen
mjensen's Avatar
Umm...not sure I get that?
Mike
Old 10-10-2009, 11:45 PM   #4
mbgmike
get what?
Old 10-10-2009, 11:47 PM   #5
mjensen
mjensen's Avatar
Sorry, when I brought up this post the first time, all it read was "crap rhis is easy." Now that I come back in here and see that there is more it makes sense
Mike
Old 10-10-2009, 11:56 PM   #6
mbgmike
Ok Hey to take a rocker panel off is not hard. Just grind the spot welds off.
don't need no stinkin spot weld cutter.
If the inner panel is ok then you don't need to brace it up. Hell call me we do this all the time. I am dirty today from doing it in fact I have not cleaned up
Old 10-11-2009, 12:34 AM   #7
mjensen
mjensen's Avatar
Well, I do have a lot of floor repair to do as well. I was thinking of starting with the floor extention piece then going from there:
Mike
Old 10-11-2009, 12:46 AM   #8
mbgmike
Yeah by looks of your pics you can use the new panel that TriPlus came out with. It will extend about 3.1/2" into the floor from th outer edge of the inner rocker panel. You will have to add some floor material but that is not too hard.
The outer floor section is a great part for aftermarket. It fits great
Old 10-11-2009, 01:07 AM   #9
mbgmike
I can show you better pics but they make me resize stuff an this site an it alot more work
Old 10-11-2009, 01:14 AM   #10
mbgmike
I can get better pics of the front . we just work and pics are not that important to us
Old 10-17-2009, 03:38 PM   #11
mjensen
mjensen's Avatar
So, do I really need to brace the cab before I cut out the floor for this 4" outer floor piece?
Mike
Old 10-17-2009, 05:20 PM   #12
white 67
i dont have any answers to you question but the best price i found on the replacement parts was on ebay and the guy ships them fast
white 67 is offline   Reply With Quote
Old 10-19-2009, 08:05 PM   #13
1lowdiesel
1lowdiesel's Avatar
stick with a supporting vendor!!
i would brace it if it's flimsy enough now. i'm actually going up to tri pro tomorrow to pick up that exact piece.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 10-19-2009, 08:15 PM   #14
mjensen
mjensen's Avatar
I ended up buying these pieces from GMC Pauls (spent a little more, but they had them in stock). I intend on buying the rest of my cab pieces from Mike's Bump & Grind Garage as Mike has been a tremendous help on this project. I'm all about supporting the wonderful vendors that support this board
Mike
Old 10-19-2009, 10:29 PM   #15
POPO1984
POPO1984's Avatar
Thats just wrong mike. Teasing me with pics of the new inner rockers. Have you been able to order any of them yet
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 10-20-2009, 06:13 AM   #16
mbgmike
Of course. we have installed them on a number of cabs. We just have the left side backordered is all. As none of our suppliers have any left. Right now I have to get the lefts from other vendors to satisfy our customers. I'm losing money on them now I hope they come in soon.
Old 10-22-2009, 10:35 PM   #17
mjensen
mjensen's Avatar
Okay, so I'm dry-fitting these outer floor peices, and have found them to be too long. Have other people had this issue, and how best to resolve it?
TIA,
Mike
Mike
Old 10-24-2009, 10:58 AM   #18
1lowdiesel
1lowdiesel's Avatar
mine fit fine actually. but i just brought them back so i can do teh whole floor.
xtremediesel.com
Old 10-24-2009, 11:49 AM   #19
mjensen
mjensen's Avatar
Hmm...I'm just wondering why mine are sooo much longer then. Maybe 40 years of washing and sitting out in the rain has shrunk my cab
Mike
Old 10-24-2009, 01:01 PM   #20
1lowdiesel
1lowdiesel's Avatar
idk i would imagine that tri plus makes your panels as well. i know the cab corners i have aren't tri plus and they fit like poopie.
xtremediesel.com
Old 10-24-2009, 02:07 PM   #21
powell72
powell72's Avatar
I cut mine in half when I did it. I've heard people say they're too long sometimes and I feel I'm not good enough to fit a piece that big so I fit the front, got it tacked in, and then fit the rear half.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 10-24-2009, 02:14 PM   #22
mjensen
mjensen's Avatar
That looks like a pretty good solution. How much did you have to cut out of there.
Mike
Old 10-24-2009, 07:32 PM   #23
powell72
powell72's Avatar
I honestly don't remember.
Chris
Old 10-24-2009, 08:41 PM   #24
mbgmike
I sent some dims with a PM for you to check your cab. I guess we have been lucky and we have installed at least four sets of these without having to cut them at all. Not a hard fix but I would shape the ends before having to cut but whatever works is good. We cut full size truck bedsides into three pieces to ship to Germany. Those guys don't mind welding
Old 10-24-2009, 08:43 PM   #25
mbgmike
Nice work by the way.
Mike
