Old 10-11-2009, 08:48 AM   #1
pitchblack86
bench to buckets swap(help)
i havent been able to(surprisingly) find any info on doing a bench seat swap to a set of buckets.
i have a 83 c10 regular cab with a bench. i was given a set of beautiful buckets and conosole out of a 85 k5 blazer.
before i go ripping out my bench is there anything i should know? is this a straight forward swap. unbolt the bolts to the floor, pull bench and bolt in new buckets?
as i've learned nothing ever goes easy. hopefully someone can chime in soon. want to get cracking on the truck today. lot of things to do, but want to do the seats first.
pitchblack86 is offline   Reply With Quote
Old 10-11-2009, 09:46 AM   #2
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Re: bench to buckets swap(help)
There are two seat brackets that are welded to the floor that you need from the blazer.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 10-11-2009, 11:29 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Actually the Blazer brackets won't work due to the floor design.
I have been told by those that have done the swap that you either need a set of truck floor tabs, or a set of Suburban brackets. The Burb brackets will need some tweaking, but can be made to fit.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-11-2009, 03:23 PM   #4
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
We're talking about two different things here.
1. You need the floor tabs that weld to the floor for the inner front of the seat slider on the driver's side and the inner front mounting bracket on the passenger side. You'll find these in a burb with buckets or a pickup with buckets.
Factory pickup buckets had a fixed passenger seat the mounted on four separate brackets. The drivers side had two rails similar to what you see on a bench seat.
2. Suburban bucket sliders are kinda close to the pickup ones, but the tab on the back of the mounting rails bends down to match the sub floor pan rather than up to match the pickup floor pan. They can be modified to fit.
3. Blazer bucket sliders are much different, much taller and not a good starting point to fit buckets to a pickup.
4. The SEATS themselves, unbolted from the brackets, can be made to fit all the different sliders. At most you'll have to drill some holes to match the different seat frames. So, the nice ones you found will work.
Read this info on Jeff's site:
http://www.73-87.com/7387garage/inte...ry_buckets.htm
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 10-11-2009, 03:52 PM   #5
pitchblack86
thanks for the reply's. this was a total failure.
seats are mint, along with the console. i pulled my bench out and instantly knew it wasnt going to work. blazer seats almost hit the roof lol. back to square one. might just settle for trying to nab a nice burban rear seat and hope that bolts right in.
Old 10-11-2009, 04:30 PM   #6
bluex
bluex's Avatar
Like ElGracho said, you just need some 'burb seat tracks and the nice buckets you have will work with some mods. Since you need the tab from a 'burb anyway you will already have the seats off and it will be easy to grab the tracks...
bluex is offline   Reply With Quote
Old 10-12-2009, 08:45 AM   #7
Jonboy
Slots go on anything!
Exactly. The Blazer floorpan is flat, and the truck and Sub floorpan has the hump to clear the fuel tanks (at least that's what it is for in the pickup). Find a burb with buckets in a junkyard, and just grab teh tracks and inner floor tabs. The tabs are welded in place, so you might have to get a bit of floor, too.
Old 10-12-2009, 12:55 PM   #8
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
mine had custom buckets and had a special looks very home made brackets can take a pic of its any help for some home grown
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
