please help!! I made a $1200 mistake
I have a 2006 4x4 wt with the 17" steel wheels. I found an old set of 16" alloy wheels from like an 02 and knew the lug pattern was the same so assumed they would fit and ordered 900 dollars worht of lt285 75 16 goodyeaer silent armor from tire rack. put the rear tires on w no problem and they look great. went to put them on the front and the inner portion of the wheel does not clear the brake caliper. I guess now i know why they went to stock 17" wheels. please help. any suggestions? maybe i can change out the calipers? or is everything different and i have to start over
![]() Join Date: Sep 2005
Re: please help!! I made a $1200 mistake
Howabout a set of wheel spa ers may some pic of what is hitting could help us help u
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
![]() Join Date: May 2007
I don't personally recommend this but I have seen a few people slightly grind down the calipers.
Charlie Daniels w/ a Tq Wrench
Won't work at all, starting in 04 GM got rid of the disk brakes in the rear, went to rear drums again, and put larger disks in the front. You cannot fit anything smaller than a 17" wheel on 04+ trucks. You also cannot fit anything smaller than 16" on 99-03 trucks.
#5 | |
Crosby 1978 Chevrolet K10 stepside NH |
It was for half ton trucks. 3/4 ton and 1 ton could use 16" wheels up to the 2010 model year. After that it was 17".
Thanks 95 S_Trucker - appreciate the help
this happened too me too, went tot the dealer with my rims off my 03 to put on my 06 for winters, got the tires mounted and went to put it on and didnt fit, lucky i bought the tires from our local dealer whos a friend and he just exchanged them for 17s and i found a set of rims on craigslist, dealer said you cant change the caliper size, so youll have to return them
I wouldnt have it any other way...CHEVROLET! ALL throttle, NO bottle!!! Theres NO replacement for displacement Current Rides 2006 Silverado ![]() ![]() Previous Rides 2003 Silverado 1992 Silverado |
Wow good to know ! I was about to buy 16" tires for my 08 Silverado for winter tires and just about did today (yikes) so stock rims it is. (for now)
"I feel the need for speed!"... as soon as I am done with my nap. |
