10-11-2009, 05:56 PM | #1 |
Lets See Some Winter Traction Solution Photos
Here are a few pictures of my solution to 2wd in Colorado winter.
My goal is to add weight that will (1) remain in place (2)is not very expensive (3) will not make a mess, and (4) reusable in the future. The "tube sand" that is sold across this country is the biggest ripoff ever. You get 40# in a "tube" for ~ $3-4. The best part about the tube sand is when it breaks all over the back of your bed. Even worse, when you do get stuck, you end up breaking into the bag early. I have used this method in the past with great success. I have a couple of 4x4 and some 2x6 hem/fir. Three 25 gal rubbermaid bins (make sure you buy the soft plastic bins, harder plastic will crack in the cold). The old gal weighs # 4,620 before, #5,220 after. That is # 600 of "squeege" mix (sand and irregular fines < 3/16"). The bins are nice because I will have a supply of dry traction sand, when I need it. I am also going to add some small plywood covers to hide my chains from thieving eyes. Total Cost: 3 bins $ 22.00 Wood/screws $ 35.00 Sand $ 7.41 Total. $64.41 Equivalent Weight in Tubesand @ 3.50/lb = $52.50 I think I have accomplished my goals. Of course, the real savings will come years down the road when I don't have to invest in the hardware. Lets see what your solutions are
__________________________________________ Sean 1972 C20 2005 4Runner |
10-11-2009, 06:33 PM | #2 |
Re: Lets See Some Winter Traction Solution Photos
Great idea! We don't get snow like you, but when we do, I take my tractor with a front-end loader and load my bed with snow. When it warms up, the weight melts away. Not for truck in garages, bad mess.
10-11-2009, 06:35 PM | #3 |
This is mine ...
10-11-2009, 06:53 PM | #4 |
My solution is to stay in California
69 Chevy 4x4 383 Power |
10-11-2009, 07:01 PM | #5 |
Just Not Low Enough!
for me its arizona. snow....whats that?
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
10-11-2009, 07:05 PM | #6 |
Good idea with the sand. I have 4 old tractor trailer tires mounted on rims I put in the bed as needed. They even fit under my bed cover. Even though it's a non posi rear, it usually does the trick.
10-11-2009, 07:20 PM | #7 |
I just put a load of fire wood in the back.
I'm not as good as I once was, But I'm as good once as I ever was. |
10-11-2009, 07:27 PM | #8 |
For traction, I sling one or two of my three-point implements into the back of this snow-mover. Another option is logs - they are free. I know people that use lead shot. Or five gallon buckets of wheel weights from the local tire store. Weight, coupled with chains on all four wheels, means I keep moving. My Chevy C10? It stays safe and sound in the garage until spring!
Although this is a Willys product, it came with a Buick 350 that runs like a top - and is still working, after all these years. Best regards Ray |
10-11-2009, 07:45 PM | #9 |
Redefining LowBudget
the tube idea is a great one just wrong material here how you fix it for CHEAP
get a truck tube cut it across ( look you have a long tube) roll a 2x4 in one end of it then nail or screw anther though the tube into the other 2x4..( look it's sealed at one end) guess whats next?? fill it with sand DUH!!! tie the other end off and your done...you can adjust the weight by filing it more or less.and if you get stuck untie the end grab the coffee can you threw in before you tied it off and sand your tires... works in cars or truck and is clean.......
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
10-11-2009, 08:20 PM | #10 |
when you live in South Texas.... Winter= rainy season..........so....
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
10-11-2009, 08:53 PM | #11 |
For me is Fort Lauderdale Florida!!! the only snow we get is the one people snore up in their nose....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-11-2009, 09:40 PM | #12 |
ewwwwwwwww
10-11-2009, 09:44 PM | #13 |
Ok. I see a little more snow than most of you guys up in Canada. Im gonna need something for weight in my truck here in a little bit. The containers of sand is a good idea, but i still want to be able to throw a snowmobile or atv in the back when need be. I was thinking about trying to find some heavy rubber mats and cut them too fit. There pretty heavy and that way i can just drive what ever on top of them. I might throw a container of sand in there too. Like the traction as needed idea. Any other ideas
10-11-2009, 10:03 PM | #14 |
This pic should be in the Volvo thread in Alternate Tinkerings!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
10-11-2009, 10:47 PM | #15 |
20' Daredevil (Ret)
Doesn't work well at the other end of California...
My solution is to engage the front axle. If that's not enough, shovel snow into the bed. If that's still not enough, stay home and stoke the fire. Nobody else will be out either.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 10-11-2009 at 10:49 PM. |
10-12-2009, 12:40 AM | #16 |
I've got (2) 14" tires that I filled with leftover concrete from a pour. I added a half round piece of #4 rebar for a handle on each. Each tire weighs around 150#'s.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
10-12-2009, 08:09 AM | #17 |
Those tubs all framed in are the best solution.Weight is easy to add.The problem is having it stay put.Around here,you shovel your bed full of snow and you might be hauling a glacier for a couple months.I clean it all out before it does the refreeze.
It snows in California and Arizona,just not on you flatlanders.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-12-2009 at 08:10 AM. |
10-12-2009, 10:58 AM | #18 |
Big innertube in the back . I have an adaptor that allows you to put water into the tube. (tractor supply). Or I just drive my subaru
10-12-2009, 11:34 AM | #19 |
Professional Grade
around here a fairly common fix is just iron weights like tractor wheel weights, tractor front end weights or weights off an oilfeild pumping unit. They are small enough to keep your bed useable. Keeping them in place can be tricky, I either find a simple solution(varries by truck) or just drive nice wich is easier said than done lol
61 GMC 9' Step Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828 67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531 71 GMC Street performer in the works Waiting for warm weather http://67-72chevytrucks.com/vboard/s...d.php?t=341946 1990 GMC Sierra GT-sold 1983 chevy 4x4-project on hold maybe sell 1969 Triuph GT 6- sold 1996 Ford I-6 5 Speed 4x4 2004 Dodge Intrepid- milage maker 1959 Ford Fairlaine, factory a/c 292Yblock- sold 1982 Honda XL500R Always lookin for other old trucks! |
10-12-2009, 12:46 PM | #20 |
I know they're a bit of money, but I've never found anything better than a camper shell! Weight is evenly distributed, and doesn't move (if you're lucky!). Then you can add bricks, etc as needed.
And about the California snow thing: It definitely snows around here, just not right in the LA basin. The fun thing when I was in high school was to ditch class and drive my '69 3/4 ton up Angeles Crest Hwy and load it with snow. We could be back in town before it melted and drive around wingin' snow balls at unsuspecting idiots... |
10-12-2009, 01:01 PM | #21 |
Hootis is as Hootis does...
Yes indeed - main reason I moved from Idaho (Eastern, near Jackson Hole) to Florida.
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires 1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires 1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires |
10-12-2009, 03:07 PM | #22 |
I like the idea. I wonder how it does in the below zero temps though.
10-12-2009, 03:37 PM | #23 |
more ideas than money
I did the snow in the bed thing when I was 16. The snow ended up packed tight and like a ball of ice. Three weeks later I ended up losing my axle seals from the extra wieght that refused to melt. From now on I will find another kind of ballast first LONG before I use snow again.
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
10-12-2009, 09:54 PM | #24 | |
01-08-2010, 11:22 PM | #25 |
colorado sean what size were the bins you used?
