10-11-2009, 06:41 PM | #1 |
HELP!!! need paint codes for my 72 C20!!!
Moderators move if necessary, but does anyone have the correct dupont single stage paint codes for my 72 C20??? My uncle has fixed the deer damage from last summers accident, but is having a heck of a time finding the right codes.... I have a pic of the spid and it just shows "14811D Med/White Blue/White"... Also here's a pic of the truck also.... Thanks in advance...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
10-11-2009, 07:00 PM | #2 |
SWB 4x4 Collector
Re: HELP!!! need paint codes for my 72 C20!!!
take it to a body shop and have them use a "Color Camera" Trust me, it is worth your time to do that. It will match the paint up to whatever the camera sees and will come up with the correct paint combination in several configurations as far as basecoat/clear or single stage. They use these for auto damage cars when only a panel or 2 need painted and it matches fading of paint and so on a lot better than just some fresh new paint. Hope this helps, Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever Last edited by 71blksuper4x4; 10-11-2009 at 07:00 PM. |
10-11-2009, 07:03 PM | #3 |
SWB 4x4 Collector
For single stage though, I have seen a lot of guys in the past use Hawaiian Blue, but like I said, try to get someone to take a paint camera over one of the existing blue areas and it should come out better than using the color coded paint.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-11-2009, 07:36 PM | #4 |
The blue is 510 medium blue and the PPG number is 2188. The white is 521 or PPG 2185. Those two colors make up the 481 paint code listed on your SPID. Your local automotive paint store shouldn't have any trouble crossing that number to a dupont code. I had a local company (PPG) mix a single stage blue and I was amazed at how well it matched.
This might help you, http://www.tcpglobal.com/aclchip.aspx?image=1972-chevrolettruck-pg01.jpg Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. Last edited by chipflyer; 10-11-2009 at 07:39 PM. |
10-11-2009, 07:43 PM | #5 |
Hope this helps.
10-11-2009, 08:08 PM | #6 |
Here is the Dupont chart up on Ebay. Can't make out the blue code because of his sample text. You might send him a note, he may tell you what the blue code is.
72 Dupont
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
