rear drum brake question
I'm in the process of rebuilding my rear brakes on my 69 C10. Can this piece be removed by unscrewing the two 3/8 bolts on the back side? One of the bolts is stripped and I can't get it out without drilling. Just need to know if it's necessary. My search is broken, is there any rear drum brake rebuild threads out there?
What?
Re: rear drum brake question
That is your wheel cylinder, and yes the two bolts behind it hold it to the backing plate.
If I were you, I would grind the head off of the stripped out bolt. Then when you get a new wheel cylinder, just buy new bolts to re attach it to the backing plate. Napa sells those pretty cheap.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 10-11-2009 at 08:39 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Take a hammer and chisel and knock the head off of the stripped bolt. Then the wheel cylinder will come off. The wheel cylinder will cost you 15 bucks or so. A new bolt maybe a quarter.
i just replaced mine this weekend. Napa had them for $8 each.
i agree grind the head and get a new bolt. |
