Old 10-11-2009, 08:27 PM   #1
dznucks
dznucks's Avatar
Rear Brake Hose Question
Does anyone know where to get a SS braided rear drum brake hose for a '69 C-10?
dznucks is offline   Reply With Quote
Old 10-11-2009, 08:34 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rear Brake Hose Question
These guys have them. I haven't ordered from them so no input there...
http://www.inlinetube.com/
Look for "Stainless Steel Power Braid Flex D.O.T. Hoses"
LockDoc
Leon
Old 10-11-2009, 09:48 PM   #3
nastyc10
nastyc10's Avatar
I have inlinetube's hoses and hardlines, very nice and easy to install.
nastyc10 is offline   Reply With Quote
Old 10-12-2009, 05:32 AM   #4
mbgmike
Any Brakequip dealer can make you one. I am sure there is one in Atlanta
mbgmike is offline   Reply With Quote
Old 10-12-2009, 06:39 AM   #5
dznucks
dznucks's Avatar
Cool, thanks. i found a Royal Brass thats a brake quip dealer near by.
Does anyone know what the fittings are called and what sizes? They look like special fittings since they have the c-clip on the backs of them. also both fittings look different.
Napa shows this for a '69 C-10 1/2 ton:
Length:22.313"
Type of Ends:7/16" - 24 & 7/16" - 20
Old 10-12-2009, 06:39 AM   #6
dznucks
dznucks's Avatar
Does that sound right?
Old 10-12-2009, 09:33 AM   #7
Eichorst69
InlineTube good prices and great service. I've used them many times.
Eichorst69 is offline   Reply With Quote
Old 10-12-2009, 01:28 PM   #8
dznucks
dznucks's Avatar
I looked at inline tube. but i also found a hydraulic hose store that sells makes hoses. They have a black anodized SS braided hose material. I also get discounts through the company i work for. it will be cheaper, look better, and they will make them while i wait.
So now i am try to find out exactly what these specific fittings are called and the sizes, so i can order them. If anyone knows where to find the specs on these hoses and fittings, let me know.
Old 10-12-2009, 01:42 PM   #9
Alex Hayley
I went to through this exercise with BrakeQuip and came up with these partnumbers to have the front and rear brake hoses made.
A few VERY important notes. First, double check the part numbers before you order the hoses. Do not trust my part number in the event that I might have pasted the incorrect parts. Second, provide your own hose length that you need. My truck is lowered which might mean that the length is different than what you need. Third, on my truck on of the male fittings on the hardline that the front hose connects to were different sizes. Since I made my own brakelines I changed them to the same fitting. My parts list reflects this change. So do not assume my parts are exactly what you need.
The total cost of the lines including shipping was about $80.
You can phone Jerry(877-431-0075) at BrakeQuip to check on the parts needed and if they are in stock. They do have a company in the next building that can build the lines for you. The name is Royal Brass and Hose(800-669-9650). You can ask for Matt or Nathan there.
If you need a starting point on your hoses you can mention my name(I am not very imaginative so it is my screen name) and they can probably pull up my order which will list all the parts they used for me.
BrakeQuip hose requirements:
Front – 2 hoses
fitting 1 – 7/16” banjo HFB448
fitting 2 – 3/8” 24tpi female HFIF01SS
length – 13.5”
Rear – 1 hose
tee 3/8” 24tpi female BQ56ASS
fitting 1 – 3/8” 24tpi male HFIM01SS
fitting 2 – 7/16” 24tpi female HFIF02SS
length – 18”
Alex Hayley is offline   Reply With Quote
Old 10-12-2009, 02:35 PM   #10
mbgmike
There you go. We are going to be getting the Brakquip equipment next year and make are own from now on.
Old 10-12-2009, 03:13 PM   #11
dznucks
dznucks's Avatar
Alex, thanks for the info. What year is your truck?
When I loook at the rubber rear brake hose that napa carries for a '69 1/2 ton C-10, it says it has a 7/16 -20 and 7/16-24 fitting. The fitting, that connects the hard brake line to the rubber line, on the front and rear of my truck is the same. So i am expecting to need a 7/16 female fitting on both the fronts and rears. A banjo fitting on the fronts and then the male fitting that goes into the T in the rear.
i have already selected some brakequip fittings that look similar to what i have, but i need to go put some caliper on them to know exactly what size they are without removing them. i hope to go to Royal fitting this week.
Old 10-12-2009, 03:14 PM   #12
dznucks
dznucks's Avatar
What diameter line did you use?
Old 10-12-2009, 04:31 PM   #13
Alex Hayley
I have a 72 C10. I did not specify what diameter of hose to use. I simply assumed that since they make brake hoses and I told them what vehicle I was putting them on, they would know better than I would what size to use. If it helps, the OD of the hose is 1/4". Or did you mean the hard line?
Old 10-12-2009, 04:44 PM   #14
dznucks
dznucks's Avatar
i meant the soft lines.
i just measured mine. i have 3/8 female connector and a banjo in the front. in the back i have 7/16 female and a 7/16 male. the other two ports on the T are 3/8 to the hard lies.
Old 10-12-2009, 04:50 PM   #15
dznucks
dznucks's Avatar
What calipers do you have up front? I have the ECE calipers. I am wondering what the banjo size is.
Old 10-12-2009, 08:15 PM   #16
Alex Hayley
I have the stock calipers which would be 7/16". If you have newer calipers, they would be 8mm I believe.
Old 10-13-2009, 06:24 AM   #17
dznucks
dznucks's Avatar
Does anyone know for sure what size banjo bolt the ECE calipers use?
