Old 10-11-2009, 08:34 PM   #1
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Things that dont work....
Spent the day tearing Bessie apart to do the "simple" P/S box swap to a '72 integral unit...These are the things I learned:
The 72 C10 power steering box does not fit 67 C20 frames with the raised areas without shimming the box out.
The 67 C20 power assist draglink will not fit a 72 C10 P/S pitman arm.
The 67 C20 inner tie rod ends will not fit into a 72 C10 draglink, the taper is huge.
72 C10 inner tie rod ends will not fit the 67 C20 adjusting sleeves as the threaded area is LARGER than the 3/4 ton unit.
I hate grease!
So now I am at a loss....what can I use for an inner tie rod end that has the smaller C10 taper and the smaller threaded shaft?
screamin_c10 is offline   Reply With Quote
Old 10-11-2009, 09:08 PM   #2
Sammy
Re: Things that dont work....
You may be needing to use C-10 parts rather than C-20 parts. Look at the FAQ under power steering. One of the postings has a list by part # for all the parts you should need. Good Luck..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-11-2009, 10:05 PM   #3
screamin_c10
Yup, I thought I would post this so guys doing a 5 lug swap on a 67-68 C20 would be aware....info on this swap seems a bit scarce....
Old 10-11-2009, 10:33 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
shimming the gear box is a bad idea. I would head up the frame with a torch and dimple it.
Its been over a year since I did my C/20 to C/10 conversion, but I coulda have sworn the pitman was the same between the two. I don't own a puller and don't recall borrowing one. (mine was already power steering)
Old 10-12-2009, 04:31 AM   #5
screamin_c10
Thanks LH, I appreciate the advice on the frame dimple. The Draglink on the 67 has a control valve with a post sticking out of it. The 67 pitman arm has a hole in it to receive said post. The 72 pitman arm has a post in it that goes through a hole in the draglink. The 2 are opposite one another. I'm gonna bite the bullet and just swap frames over and have all the benefits of the 72 under the 67 body.....
Old 10-12-2009, 08:02 AM   #6
trucks72
trucks72
trucks72's Avatar
If you use a solid shim, not just washers stacked up you should be fine.
trucks72 is offline   Reply With Quote
