10-11-2009, 10:19 PM | #1 |
A/C removal
Hi all,
Im running no A/c in my truck, can I pull the core out ok and put a panel over the hole ? is the heater core on the inside of the cab ? And can anyone tell me what the small black globe pointed out is, it has a vacuum line which runs inside the cab. Thanks |
10-11-2009, 11:12 PM | #2 |
Robert Olson Transport
Re: A/C removal
thats the evaporator.. you should prolly remove the AC unit and replace it with the regular non AC box.. the heater core is inside the cab
10-12-2009, 02:20 AM | #3 |
Re: A/C removal
i tried that, thinking it would work...definitely a pain in the neck. i would either leave it alone if you still want heat or pull the entire system. and add a piece of sheet metal over the fire wall. then maybe put in a heater from summit or something. that's what i did and it works pretty well, without the clutter on the fire wall.
http://www.summitracing.com/parts/SUM-991102/
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
10-12-2009, 08:41 AM | #4 |
Slots go on anything!
Re: A/C removal
The ball is a vacuum reservoir. It stores vacuum for the A/C controls, IIRC. The hole for non A/C and A/C is completely different. I second the notion to pull everything, if you are trying to clean up the firewall.
10-12-2009, 11:02 AM | #5 |
Re: A/C removal
in rereading the thread yes that is what the vacuum does it allows the vents to shift from upper to lower and the ac door etc
10-12-2009, 04:44 PM | #6 |
Re: A/C removal
thanks for the replies,
Ill look at changing out the whole lot then I guess. |
