frame fix
i have a real nice 71 swb truck i paid alot for it and it has the frame cracked over the rear coil spring the spring hanger had rusted into and some dip**** kept driving it and cracked the frame so we got a new hanger and the cup at the top of the spring and cleaned up the frame and painted it and drilled holes and bolted a peice we cut from another frame painted it and bolted it on the inside of the frame does this sound like it will be strong enough b4 we fixed it u could feel it snag on that side in the curves but now it drives fine so will this work or is there a better way to permitlly fix the frame or is there no way to fix it properly. thanks alot.
is it clear
i was hoping someone would have replied is it clear on what i mean i hope so somebody please let me know something
Post some good pics of your repair and you should get plenty of opinions
Fabricate till you "puke"
I agree, a pic would be helpful as to the extent of the damage,& the repair done.As a rule, My thoughts are on a cracked frame rail , that welding the patch would be a more permanent repair. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
pics
we have like 4 inches of snow right now but as soon as i get a chance ill try to get some pics
