Suburban Hick
![]() Join Date: Aug 2008
4" lift kit questions
I originall was going to just do a 2", but have decide to opt for a larger 4" inch lift kit. I currently have 4" lift front springs, new u bolts front and rear, know where i can get rear blocks and i am putting the 56" long springs on my half ton as some of you probably remember from my last thread. I know for sure i still need to get a different pitman arm, longer brakelines, shocks, shock boots and hardware.
But..... What about the sway bar, do i need lowering brakets for that or will it be ok How about driveshafts, will they be ok in there stock length? Dual or single steering stabilizer? Alos where is the cheapest place to get the things i still need. Thanks in advance.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
OL BLUU
![]() Join Date: Mar 2004
Re: 4" lift kit questions
I dont know if the 84' F/S Blazers are different, but I did a 4" on my old one. The brake lines were fine as stock. Also some other input:
What about the sway bar, do i need lowering brakets for that or will it be ok? Mine was fine, no adjustment needed. How about driveshafts, will they be ok in there stock length? Mine was fine, no adjustment needed. Dual or single steering stabilizer? I kept the single and replaced it with a new Rancho. Also where is the cheapest place to get the things i still need. Craigslist, Ebay, depending how fast you want it. Or just order from a 4x4 shop, etc.
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 10-12-2009 at 03:01 PM. |
Suburban Hick
Thanks for the input, I missed out on a complete brand new lift kit on the cl and haven't been able to find just individual piecs on ebay, just kits. The drive shaft part is a loadoff my mind. I'm sure if stock ones fit on a blazer still they should be the same on a truck.
OL BLUU
If I remember right... if you go more than 4"... that's when your run into more problems/mods. Hence I only went 4" o at the time...
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
Suburban Hick
Yeah i couldn"t remeber if it was 3 or 4 inches that you could go to without changing much
i just did a 4" lift all around on my 78 k10.
didnt need to do anything. brakelines were fine,driveshafts were fine,everything was fine.just installed the lift,then the 35's. great size lift in my opinion.youll like the heighth.pretty high. |
Suburban Hick
dmartin1- Did you have to change the pitman arm or was it alright as well?
![]() Join Date: Feb 2001
I would get a riased steering arm. About 60 bucks. You can do without it but your truck will not steer in one direction as much as it will with the new arm. Most 4 inch kits also give you small brackets to relocate the front brake lines under the frame if needed.
Suburban Hick
I've noticed in all the kits online that they have the relcation brackets for the brake lines, but i'm piecing a kit together, cause a friendof mine gave me new u bolts and a sweet price on the front springs. I'm thinking about getting new brake lines any way as they are pretty old and getting dry rotted. Shoot i have to replace one of the steel lines this weekend because it rusted out.lol
![]() Join Date: Feb 2009
Meh, if you want it done right, you need new brake lines, longer parking brake cables, possibly longer driveshafts (front more-so) and a raised steering arm. Even then you will get bump steer.
On my K5 with flipped rear shackle, I also needed a CV on the rear driveline. I REALLY want to do X-over steering next. Bump steer gets annoying. Some of this might not apply to a '69 but the fundamentals are the same.
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() Last edited by Oilbrnr; 10-13-2009 at 03:13 PM. |
