Old 10-12-2009, 07:58 PM   #1
timcrow00
any with a 6.0 4l80e 4x4 in older truck
ive heard of some people putting the 6.0 and 4l80e and their 2wd trucks but ive been lookin into doin the swap into my 85 3/4 ton 4x4. i know i would need the ecu and everything for the motor and trans, but can i use my original transfer case or do i need to use the newer transfer case. and what about the the shifter linkage for the trans and if i use the newer transfer case how would i change it from 2wd to 4wd
timcrow00 is offline   Reply With Quote
Old 10-13-2009, 10:18 AM   #2
timcrow00
Re: any with a 6.0 4l80e 4x4 in older truck
anyone got some info?
Old 10-13-2009, 10:36 AM   #3
thump16
thump16's Avatar
Try
www.ls1trucks.com,
www.hotrodlane.cc "in their install section"
www.ls1tech.com "most helpful info"
There are a few members on here that have did the swap also. I'm sure someone else will add to this post. You can look up members PCM cobra, Glock35ipsc or search this forum for LS swaps and you will find the info you need. Hope this helps.
Sledge
thump16 is offline   Reply With Quote
Old 10-13-2009, 12:25 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
The problem with using a 4L80E and it's transfer case it (if I remember correctly) the front drive shaft comes out on the opposite side compared to a NP203 or NP205.
I'll be installing a 5.3 into my 70 sometime next year. I'm going to use a 700R4 and keep the original NP205. GM makes a flexplate adapter so that there are no issues when using the original transmission, the adapter allows you to use the LS flexplate and bolt it up to the TH350/TH400/700R4/4L60 torque converter.
I do not know for sure if your transfer case would bolt up to the 4L80E. My first though is that no, it wouldn't. But someone might actually make an adapter just for that application. Try pirate4x4.com, there are guys doing these swaps into 4x4's all the time on that site.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-13-2009, 01:48 PM   #5
nekkidhillbilly
4l80 bolts to the np205 and was offered in the the later square bodie crews
and if i did a 5.3 swap id grab the 4l60e with it over the 700 they have the same output shaft and will bolt right in the same spot as a 700 but you get a little stronger trans and ecm controlled
nekkidhillbilly is offline   Reply With Quote
