10-12-2009, 09:15 PM | #1 |
Help with '65 Cab Mount bracket Dimensions
Recently stripped my '65 down to the frame, and found that the holes in the cab mount brackets are rotted. I have the material to fab new bracket tops, but I need dimensions, Center to Center cross car, hole diameter, and maybe frame edge to center line. (I have seen the frame drawings from the assembly manual on here and none of them are for the '65 frame) Thanks in advance.
10-14-2009, 08:56 AM | #2 |
Re: Help with '65 Cab Mount bracket Dimensions
btt
10-14-2009, 08:21 PM | #3 |
I have a 65 frame & could get you dimensions but not until this weekend. I'll check back here & post them up if someone doesn't beat me to it.
10-15-2009, 08:45 AM | #4 |
SCOTI Thanks alot, I couldn't figure much of anything out from mine, the holes were all different sizes some of them as big as the bushing.
10-15-2009, 10:32 AM | #5 |
I had to re-drill mine because I plated the frame in that area. On top of that, the frame I'm building is a 68-70, so I had to use the 65 frame (it was bent) as my guide on the dimensions.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-15-2009 at 10:32 AM. |
