Old 10-13-2009, 01:58 PM   #1
Daves72'GMC
Question 72' front stabilizer bushings?
One of the front bushings is bad , How do I replace it , Do I need to jack up the truck etc. Thank you.
Daves72'GMC is offline   Reply With Quote
Old 10-13-2009, 02:05 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: 72' front stabilizer bushings?
For a sway bar bushing you shouldn't need to jack up the truck. Just unbolt the sway bar from the a-frame and the frame mount and replace the bushing and rebolt it back to its mounting brackets
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 10-13-2009, 02:31 PM   #3
Daves72'GMC
Question Re: 72' front stabilizer bushings?
Does the open end of then bushing face toward center of truck or toward the wheel? Thank you.
Old 10-13-2009, 03:07 PM   #4
Daves72'GMC
Sorry, I'm talking about the bushings at the ends of the stabilizer bar, Do the openings of the bushings face toward the center of the truck or toward the wheels? Thank you.
Old 10-13-2009, 03:27 PM   #5
Daves72'GMC
Smile Re: 72' front stabilizer bushings?
Help, I'm under the truck.Does someone know which way the opening of the bushing goes? Thank you.
Old 10-13-2009, 07:14 PM   #6
Daves72'GMC
Ttt
Old 10-13-2009, 07:46 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It doesn't matter if the seam is inboard or outboard. Slide the new bushing on the bar, slip the clamp over the bushing and install the bolts.
You probably have a power steering leak you need to fix too. That's usually what destroys the old one. Is the area real oily ?
Old 10-13-2009, 08:42 PM   #8
Daves72'GMC
No its not oily, The guy that restored my truck didn't put them on right . just wanted to put them on the right way.Thank you for the info, I appreciate it.
Old 10-13-2009, 11:16 PM   #9
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
They also just wear out. You ought to see mine.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
