Old 10-13-2009, 02:33 PM   #1
Baby John
Need to help my brother find a part
My brother is restoring his 1978 Suburban and is looking for some sort of part that he says is designed to hold the rear of the hood down flush with the cowl. Here's what he writes, "Meanwhile I am in need of the hood hold down brackets . This is a two part piece that pulls the rear of the hood down when you lower the hood from the front. The part that mounts to the firewall has a cone shaped apparatus on the end that engages a simple u-shaped bracket mounted to the underside of the hood. The cone shaped end slides into the bracket and pulls the rear of the hood down flat with the body as the hood is lowered. I need both pieces."
I searched LMC's catalog and just don't see anything close to that. I know this is in the wrong forum so I apologize for that, but for some reason I'm blocked from any other forum but the 67-72 group.
Can someone help me first identify this part and then possibly direct me to a source for one?
Baby John is offline   Reply With Quote
Old 10-14-2009, 05:18 AM   #2
JimKshortstep4x4
Re: Need to help my brother find a part
Having never seen one on the later trucks, I have to believe that it is an aftermarket assembly.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-14-2009, 05:29 AM   #3
I'm not sure what heis talking about, but I moved your thread to the board aea you will have a better chance at find your answer.
Old 10-14-2009, 06:16 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i have a 78 suburban, and there is nothing like what he describes.
If the trear of the hood sticks up, then it needs the hood/hinges adjusted, or new springs on the hinges.
Old 10-14-2009, 06:18 AM   #5
lax54650
i have never seen such an animal... i've had MANY on and off in the 80s when i worked in dealer body shop .. when the back of your hood does not lay down with the cowl i believe your stock hinges have issues. binding up or loose and sloppy. lube the h3ll out of them. those hoods had a tendency to buckle just in front of the hinges due to tight hinges.
lax54650 is offline   Reply With Quote
Old 10-14-2009, 08:02 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
I believe what he is looking for is a piece that was early 80's. It may have been 80 only to work with the 73-80 style hood.
It was designed by GM to prevent the hood from lifting up on impact. It mounts in the center of the firewall and the bottom rear of the hood.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-14-2009, 12:58 PM   #7
bigblock73
yeller
bigblock73's Avatar
OK, this is news to me.
Have a pic there Ken?
bigblock73 is offline   Reply With Quote
Old 10-14-2009, 01:24 PM   #8
Baby John
Thanks, it sounds like you recognize the part. Now to locate one for him. First to identify the name of the part. If you do have a picture I might could send it to my brother and confirm if this is the part he's looking for.
Old 10-14-2009, 01:33 PM   #9
bigblock73
yeller
bigblock73's Avatar
Actually, I never heard of or seen one of these...but would like to.
I am hoping Ken might, since he knows a little about them.
Old 10-16-2009, 08:49 PM   #10
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Smile Re: Need to help my brother find a part
I know what you are talking about. I believe I have one. I will check for you if you haven't already found one. I will take some pics. Its still on a truck I have I am parting out.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 10-16-2009, 09:06 PM   #11
Conundrum
Conundrum's Avatar
My 79 Blazer has one and so does the 80 1ton that my dad just bought. Up until I got my Blazer I had never seen or heard of one either. If it wasn't dark out right now i'd take a picture of them.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 10-16-2009, 09:47 PM   #12
Conundrum
Conundrum's Avatar
I was able to take the pictures anyway.
Gotta love the canon rebel.
The part in the hood
The part on the firewall
My dad told my that these were to keep the hood from going through the windshield in a head on collision.
Old 10-17-2009, 05:23 PM   #13
lax54650
never seen one... never too old ....
Old 10-17-2009, 11:12 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats it.
texassquarebodies-Tony you have/had one on that Blazer we pulled the core support from. Was that an 80 Blazer?
Articles-
"Refining Sierra"
Old 10-21-2009, 01:14 PM   #15
dropd80s
dropd80s's Avatar
my 78 K5 2WD has this on the fire wall but the hood is from onther year and doesn't have that half.
dropd80s is offline   Reply With Quote
Old 10-22-2009, 04:34 PM   #16
Baby John
Thanks very much. I am going to send these pics to my brother and see if this is in fact what he's talking about. If so, how much do you want for it?
