10-13-2009, 09:23 PM | #1 |
Intentionally Left Blank
Brake Booster Info
I have a brake kit from Early Classic Ent and I'd like to upgrade to power assist. I have the 11" disc in the front and stock drum rear. The master cylinder is a dual reservior that came with the kit. On a '65 what booster should I use? Do I need any brackets? I don't want anything too touchy, but I got a cramp after cruisin' the other day. Any help would be appreciated.
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
10-13-2009, 11:32 PM | #2 |
Senior Enthusiast
Re: Brake Booster Info
I'm using the 9" slimline booster from Master Power Brakes shown at the following link:
http://www.mpbrakes.com/products/search-results.cfm There are times I wish I had gotten the 8" dual diaphram booster instead for a bit more power, but it wasn't released at the time I did mine. Perhaps Early Classic has a similar offering. Although the booster shows as an assembly with the master cylinder, MP does sell the components separately if you call them. I ran mine with manual discs for a few years, but it got to where it was hurting my back to make hard stops. The 9" booster is a big improvement, but is definitely not overboosted. The link didn't work, here's the picture of the two booster styles: Last edited by markeb01; 10-13-2009 at 11:40 PM. Reason: link didn't work |
10-13-2009, 11:55 PM | #3 |
60-66 Nut
I can provide you with a bolt on bracket (no holes to drill) that will allow you to use an OEM sytle booster that you can purchase either at your local auto parts store or at a salvage yard. You can see it in the link in my sig. Let me know if you're interested.
10-14-2009, 07:12 AM | #4 |
If buying the oem reman booster for these years all the ones we sell have the bracket on the booster. Did you get a MC that will work for manual and pwr brake apps? Or just a manual MC? You can put just about any kind of booster on just depending on the room you have and if you want single our a dual diaphragm. We have just about the lowest prices in the country on brake parts. We are also dealers for MPbrakes.
