10-13-2009, 10:03 PM | #1 |
Truck cab on a Suburban frame?
Thinking about buying a '77 suburban for parts...I'll have a lot left over when I'm done. Just theoretically speaking, could you take the body off of a suburban frame, and bolt on a truck cab without the bed? Would everything line up right?
I'm starting to think it would make a good flatbed...am I nuts? |
10-13-2009, 10:54 PM | #2 |
Robert Olson Transport
Re: Truck cab on a Suburban frame?
the chassis on a burb is wider so it wont work.. trust me i bpouht a burb trailer hitch and it wouldnt work it was too wide
10-13-2009, 11:53 PM | #3 |
Hmm...aren't the front clips basically the same as the ones for the trucks? I wonder if maybe the 'burb frame is wider at the back but not the front?
Hmmmmmmm.............. |
10-13-2009, 11:54 PM | #4 |
Not sure about a regular cab but a crew cab will
1949 Five Window, 1973 Step Side, 2000 Z71 |
10-14-2009, 12:21 AM | #5 |
10-14-2009, 12:33 AM | #6 |
not mine but I built a shortbed crew for my cousin using the front of a burb frame everything to the second set of cab mounts lines up perfectly so doing this should work out fine
10-14-2009, 12:48 AM | #7 |
Sweet! The 'burb frame was going to get cut up and hauled off to the scrapper anyway. I can probably put together an extra flatbed truck from leftover parts that aren't worth anything.
Is the suburban wheelbase the same as a LWB truck? |
10-14-2009, 09:01 AM | #8 |
Still plays with trucks
That is really odd. My trailer hitch and rear bumper came off of an 86 Suburban and bolted right up to my 67 C-10 and are now on my 78 K20. Maybe they gave you the wrong year part?
10-14-2009, 05:54 PM | #9 |
frames are the same width and a burb frame is same wheelase as a longbed. just need the rear cab mounts off the old pickup frame. fronts are same
1981 Chevy C30 440 Holmes 42K one owner miles |
10-15-2009, 04:06 AM | #10 |
Hmmm, so I guess now I'll have to find another parts truck to rebuild the parts suburban after I take a bunch of stuff of it?
Maybe it's time to have the doctor adjust my meds.... |
10-15-2009, 06:37 PM | #11 |
Actually I believe the suburban wheelbase is slightly less than a longbed reg cab, by a couple of inches.
The info I found shows the sub to be 129.5" and I know the longbeds are 131.5".. Wouldn't make a lot of difference but the rear tires might be visibly more to the front of the wheelwell if a longbed was mounted on a sub frame. I believe the picture of the crewcab above may be on a reg cab lwb frame. Similar to Cousin Willard,,
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 10-16-2009 at 11:01 AM. |
10-15-2009, 06:50 PM | #12 |
you may be right. i found this on line
The fuel tank was moved to a spot outside the cab, on the right frame rail. C10/K10 pickups with an 8-ft. box had a 131-1/2-in. wheelbase, also used for many 1/2-ton chassis models and C30 models. C20/K20 trucks, except Suburbans, were on a 127-in. wheelbase.
10-15-2009, 08:41 PM | #13 | |
I'll have to look at the buildsheet on my C30 and see how long it is... Definately not an issue though, I'm just trying to build an old junker with a custom flatbed. Good beds are about the only thing in short supply around here. Last edited by Number21; 10-15-2009 at 08:59 PM. |
10-15-2009, 11:01 PM | #14 |
Yesterday, 06:50 PM #12
truckfan Registered User Join Date: Apr 2009 Location: Lawrence KS Posts: 141 Re: Truck cab on a Suburban frame? -------------------------------------------------------------------------------- you may be right. i found this on line The fuel tank was moved to a spot outside the cab, on the right frame rail. C10/K10 pickups with an 8-ft. box had a 131-1/2-in. wheelbase, also used for many 1/2-ton chassis models and C30 models. C20/K20 trucks, except Suburbans, were on a 127-in. wheelbase. __________________ 1977 C-10 Bonanza 454. Tilt, Cruise, PW/PL A/C (all works)114K original one-owner (not me--I'm second) miles. Square body, 2 door regular cab long bed pickups had a 131.5" wb. Square body Suburbans had a 129.5" wb. Last edited by Dooley; 10-16-2009 at 11:56 AM. Reason: Others were editing their mistakes |
10-16-2009, 11:00 AM | #15 |
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
10-29-2009, 06:16 PM | #16 |
so did they list the suburban wheelbase in the glove box?
I picked up a used glove box liner that had a spid label that said 129.5 wheelbase...I assumed it was a long bed truck. What is the wheelbase of a crew cab long bed?
CHEVY ONLY |
10-29-2009, 06:45 PM | #17 |
Looong
164.5"
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 10-29-2009 at 06:46 PM. |
10-29-2009, 07:46 PM | #18 |
holy schmolie.....
CHEVY ONLY |
10-29-2009, 09:29 PM | #19 |
http://chuckschevytruckpages.com/framespecs.html there you go chucks chevy pages has a listing of all the chevy truckframes used and there sizes and a ton of info on interchangeabillity
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
