Old 10-13-2009, 10:08 PM   #1
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
What would you do?
So I have decided to swap the frame on Bessie over to the 72 C10 frami I just picked up. I want to use the truck as a driver, home depot, dump run, haul a small traier type of goto truck. No really heavy hauling will be done without the use of a trailer.
Now I have some decisions to make. the frame is a GMC frame so it has a leaf sprung 12 bolt under it. Bessie has the 3/4 ton coil / trailing arm setup with a reversed leaf overload setup. I cant decide if I want to keep the 1/2 ton leaves or if I want to swap in the 1/2 ton axle using the 3/4 ton coils and trailing arms? I eventually want to drop her down 3-4 inches in the rear with a C-notch.
So basically I want a 5 lug Daily driver that can haul a load with a decent stance....throw me some opinions on this
screamin_c10 is offline   Reply With Quote
Old 10-13-2009, 10:53 PM   #2
nicolas72gmc
nicolas72gmc's Avatar
Re: What would you do?
From what you described of the Gmc frame and what you want to do with it, I would just keep the leafs. I have leafs on mine and dropped the rear 5". I have hauled prob. 1000# in it and it bottomed out once. I did pull a 5X10 trailer with a new crate 350 with an engine lift in the bed of the truck and It did really well. If you only want to go 3 or 4 inches, you could load it up and probably not have any problems. Plus you won't need a c-notch with only 3-4 inches of drop. Hope this helps.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 10-14-2009, 02:45 AM   #3
screamin_c10
Thanks for the info Nicolas... How did you drop yours? new springs, shackles or a combo of both? Do you have a pic of the stance?
Old 10-14-2009, 08:38 AM   #4
nicolas72gmc
You're welcome. I used 4" drop leafs from ECE and two position shackles from brothers. The shackles have two positions to tailor it to what you need. I think 1"and 2" drops. I used the 1" spot. Since we can't post pics right now, you'll have to wait or go to my profile I have some there.
Nick
