Old 10-13-2009, 11:41 PM   #1
Davetopay
What casting number heads on a 70 350?
Any one know? I was just curious what SHOULD be on my motor. I do get the feeling that it has been gone through at some point though as the head bolts are now studs. Should this be a 4 bolt main or 2? I haven't been able to find the block casting number on the pad behind the alternator. Could it have been milled off?
Davetopay is offline   Reply With Quote
Old 10-13-2009, 11:48 PM   #2
KrazyAz
KrazyAz's Avatar
Re: What casting number heads on a 70 350?
http://www.mortec.com/
good site for cast numbers
KrazyAz is offline   Reply With Quote
Old 10-13-2009, 11:55 PM   #3
Davetopay
Good looking out! Thanks!
Now I just need to narrow down WHICH ones they are.....several are listed..lol
Old 10-13-2009, 11:58 PM   #4
Davetopay
Guess I need to pull a valve cover....probably a #3927185 or some other universal part
Old 10-14-2009, 12:04 AM   #5
KrazyAz
KrazyAz's Avatar
valve cover best bet also ill see if i can find out what accessorie holes or how many were on 70 heads.are u looking for originals to put on there or u have on already?
Old 10-14-2009, 07:12 AM   #6
Davetopay
I am just trying to prove to myself what is going on under the hood of this truck. I keep seeing engine bays with the alternator on the driver side, but mine is on the passenger side. The block has been studded in place of head bolts....numerous other little things that make me wonder if the engine may be a swap job. It does have power steering. I'll have to get down to some cleaning and break out some mirrors to see if I can find the bell housing pad numbers on the block because there is nothing to read on the passenger side at the machined pad by the head.
