Old 10-14-2009, 02:40 PM   #1
stepside85
stepside85's Avatar
N2trux
Just wondering how the new air ride feels? I was thinking going that route or coilovers like on the old hotrods.
1985 GMC S/S. Under complete reconstruction.
stepside85 is offline   Reply With Quote
Old 10-14-2009, 09:53 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: N2trux
I plan to do a wrap up on my build thread, but it's been raining here for three weeks now. Hopefully it will be nice enough this weekend to get it out and get quality pics.
A quick summary-
On the front I already had a C-20 sway bar, so the heavy duty "Muscle Bar" will be about the same. Having the Posi-Link end links will ceartainly allow better articulation and eliminate the possibility of binding. The addition of tubular Strong Arms won't make much difference as far as feel, but they will allow better alignment.
The rear is a complete different story. There was absolutely nothing wrong with the AOL system. It did exactly what we wanted by allowing us to bag the rear with minimal effort. The downside is it had a very narrow range of "sweet spot" that was dialed in by the use of a 2" block. Anything lower than the "sweet spot" and it bottomed out. If I set it a bit to high, the ride got stiff rather quickly.
With the AirBar 4 link installed, I have a much wider range of acceptable pressure settings. Probably triple of what it was. I can ride much lower and not bottom as easily. I can raise it higher and it's not as stiff. Some of this is because of the 4 link but most of it is due to the bag location. The location of the shocks and their angle is a benefit as well.
My thoughts are that if you want the best truly "bolt on" system offered, this is it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-15-2009, 01:00 AM   #3
BIG KRIS
BIG KRIS's Avatar
Re: N2trux
I have been wondering the same thing and having the same idea not sure to go coil overs and 4link rear,porterbuilt or art.
BIG KRIS is offline   Reply With Quote
Old 10-15-2009, 01:02 AM   #4
BIG KRIS
BIG KRIS's Avatar
Re: N2trux
N2TRUX are you the guy thats running the full ride tech kit?
Old 10-15-2009, 07:46 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: N2trux
It depends on what you are after. If you want to lay rockers then go with Porterbuilt. If you want to go as low as posible and not cut your bed or inner fenders, the Air Ride kit is the best bolt on system made.
Big Kris- click the link in my sig for the complete build on my suspension.
Articles-
"Refining Sierra"
Old 10-15-2009, 12:51 PM   #6
stepside85
stepside85's Avatar
Re: N2trux
Thanks for the reply. I 'll be looking forward to you wrap up thread.
Old 10-15-2009, 06:57 PM   #7
BIG KRIS
BIG KRIS's Avatar
Re: N2trux
N2TRUX if you could compare your truck to a static drop at ride height and airred out which drops would it be.5/7 or 6/8 4/6? Just would like a idea where it would sit at and roll.
Old 10-15-2009, 09:31 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: N2trux
I can't honestly answer that. Let me get some measurements with it at ride height and get back to you.
Articles-
"Refining Sierra"
Old 10-16-2009, 05:18 AM   #9
BIG KRIS
BIG KRIS's Avatar
Re: N2trux
Ok cool...
Old 10-18-2009, 06:40 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: N2trux
I measured it at full drop. It is 26" in front and 25" in the rear. I forgot to measure at ride height. I'll have to get those later.
Here it is air full up-
And down-
Articles-
"Refining Sierra"
Old 10-18-2009, 08:53 PM   #11
79Silv4x4
Workaholic
79Silv4x4's Avatar
Re: N2trux
And down-
Does it turn w/o rubbing aired down? Just curious, never had a truck that low. . . .
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 10-18-2009, 09:24 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: N2trux
I have never tried to turn it much. I don't drive with it down expect slow rolling through the local cruise spots.
Articles-
"Refining Sierra"
Old 10-19-2009, 12:20 AM   #13
BIG KRIS
BIG KRIS's Avatar
Re: N2trux
Thanks...Man i'm only starting to like these things when they are low...
