what gear ratio
hi quick question (hopefully)
i am wondering was gear ratio came in the the typical coil sprung c10's I have 4.11 gears and need to change gears or swap axles Or what year axles will swap in 73 and up i can't afford to swap t o 5 or 6 lug.
Mike K Friend of Bill W Last edited by jd4300fel; 10-14-2009 at 05:26 PM. Reason: addtional information |
Re: what gear ratio
Mine had 3.08 gear ratio.
Re: what gear ratio
Apparently in the 1/2 tons there was a big range of gears available from 3.08 to 4.10. I think only the 3/4 or 1 ton's could be had with 4.56 or 5.something's
Re: what gear ratio
3.73's and 3.08's are common
'72 cheyenne super step, '05 long bed gmc |
its all about the +6 inches
Re: what gear ratio
4.10 avalible but uncommon
3.73 and 3.07 were both very common and both standard with certian powertrain combos. I can't fugure out the second part... if you have a half ton, then why would you need to swap to a 5 or 6 lug? It should already be a 5 or 6 lug. There are no bolt in rear axle assemblys after 72 |
Re: what gear ratio
longhorn, my current truck is a c20 that has the dana axle with 8 lug. i am looking at a gear change. a person is parting out a C10. (krazyray ) trying to decide if i do gear change and keep the 8 lug 600$. or put a 5 lug rear axle and then convert the front. Does any one make a conversion for the front the just replaces the rotor?
Mike K Friend of Bill W |
Re: what gear ratio
you won't be able to just toss C/10 gears in a C/20. The only way that'll happen is if they both have dana60 rear ends which is so unlikely that we can all assume it isn't so.
