10-14-2009, 05:12 PM | #1 |
Original specs from 1970????
I am wondering if there is somewhere to go and find out the original specs of a 70 C20?
Like horse power,torque,etc? Mine came with a 350 but was replaced some time ago with what I thought was a 350 but have not run the block numbers yet. I bought what I thought was a good running rebuilt 350 to replace this one which is wore out,smoking,burning oil. I ran the numbers only to find I bought a 307. I am in the process of getting my money back.He said he would refund it but we all know how that goes. Other question is if I get stuck with this 307 which has had valve work and high compression pistons,how much of a drop off is this from an original 350? I removed the intake,heads,cam and verified it LOOKS new/rebuilt. Thanks for any help anyone can give. AJ Last edited by ajcan; 10-14-2009 at 05:25 PM. |
10-14-2009, 06:31 PM | #2 |
member #16
Re: Original specs from 1970????
The HP on a 1970 350 c.i. 4bbl is 255. Cant help on torque.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 10-14-2009 at 06:32 PM. |
10-14-2009, 06:35 PM | #3 |
Not sure if this helps you or not but I have some specs from my Chilton that bases the power/torque on of course displacement.... and carb size..... nothing specific about C10 or C20
10-14-2009, 06:38 PM | #4 |
the factory brochure from 70 rates the 307 at 200 hp and the 350 at 255hp.
10-14-2009, 06:59 PM | #5 |
Thanks for the answers.
255 versus 200 is quite a bit of difference. Not sure what mine us putting out now but nowhere near 255 I'm sure. So over what I have now I might not notice but I will know. Let's hope I get my money back. AJ |
10-14-2009, 08:53 PM | #6 |
factory service manuals available cheaply from most all vendors have loads of specs and on top of that they tell you the proper way to fix stuff
