67 C10 327 PCV Question
The truck was originally an Oregon truck so I don't think there would have been a PCV system on it originally. There is however a hose running from the back of the intake manifold and laying on the inner fender with exhaust coming out. Where is this supposed to be connected to, or can someone just show me how to hook the PCV up properly. It has an aftermarket 600CFM Holley 4 barrel electric choke carb.
The valve covers have no oil ports. The oil port is in front of the intake manifold. Thanks ahead of time if anyone can help me out.
Eric ![]() ![]() ![]() ![]() 1995 Ford F-250 4x4 Powerstroke, 342k "Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known." -Ronald Reagan |
MOVE OVER
Re: 67 C10 327 PCV Question
does the truck have power brakes? are they aftermarket valve covers or orginal?
No matter where you are..... There you are... Buckaroo Banzi |
Between Trucks...
Does it have an auto transmission?
Beat it to fit, Paint it to match... ![]() |
Just Not Low Enough!
a picture may be able to answer a few more questions about the problem.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
That is a Road Draft tube.
I dun gradjiated collij!!!
I have a 67 C20 that is original to oregon with a 327. It has no provisions in the valve covers, there is however a tube that comes up from the rear of the block with a PCV valve inline. The other end connects to the base of the carb as usual.
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
So we cant post pics at the moment...but if you look at this thread second pic you will see where the PCV valve goes. That would be the large hose just behind the carb carb mounting surface. My truck is about as factory original and unmolested as you can get around here, so I have no doubt it is the original setup. Hope this helps....
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 10-14-2009 at 07:58 PM. |
Thank you for the help.
They are manual drum brakes, so no vacuum is being used from the intake manifold for the power booster. It is a manual transmission, stock valve covers. Sorry I can't take a pic at the moment.
Eric ![]() ![]() ![]() ![]() 1995 Ford F-250 4x4 Powerstroke, 342k "Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known." -Ronald Reagan Last edited by 67chevylongbed; 10-14-2009 at 08:56 PM. |
