10-14-2009, 09:52 PM | #1 |
67 Chevy Stepside
Is the front door on a crew. and
Is the front door on a crew cab the same as reg cab. how much trouble is it to take a 4wd crew cab duelly to a 1/2 ton 4wd
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
10-14-2009, 10:04 PM | #2 |
Kid's Mechanic
Re: Is the front door on a crew. and
Front doors are the same. some of the 3/4 four door the spring perches are the same as a 1 ton and would have to relocate them on the 1/2 ton rear.not sure on the front axle
10-15-2009, 05:36 AM | #3 |
Why would you put 1/2 ton running gear under a truck like this? The axles you have can be converted single wheel if this is the issue.
1949 Five Window, 1973 Step Side, 2000 Z71 |
