2wd to 4x4 frame swap
Im looking to buy a 4x4 frame and switch my 69 2wd over because i want it lifted "my preference" because no one makes a kit for the 2wd but everyone under the sun has one for the 4x. Has anyone done this or know of the work that is involved? i figure almost all would mount up? just have to replace the body mounts and such but then again i have no clue? pics of any conversions? Thanks, Mark
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
Re: 2wd to 4x4 frame swap
I just finished putting a 67 2wd body on a 71 4x4 frame, you will need 4x4 or 3/4 ton body mounts and a high center hump for the floor of the cab other wise it bolted right on.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin ![]() 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
60-66 Nut
![]() ![]() Join Date: Mar 2007
As long as you get a '69-'72 frame it will all go together relatively easy. The '67's and '68's use oddball springs, but you could work around that by changing the spring hangers to the FGB52's and a first gen shackle flip from DIY4X.
awesome thanks guys. now the trouble is to find the frame lol. . hey bhoeger70 do you have any pics of the swap from before and after with the height and the stance of the truck?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Only prob is i need like the full suspension i cant have it sittin i gotta swap it quick lol. but that is a pretty sweet deal
![]() Join Date: Oct 2006
Why not convert your 2x to 4x with the 2x frame. If you want to lift it any way. It will be mutch easyer than a full frame swap. and if you lift it you wont be using the stock 4x springs any way. what you need it a DYoffroad b52 kit, that will be all your mounts. and also one of ther engine cross member kits. then a pair of stock 52" springs. a front axle, preferabley with disk brakes. and a u bolt kit. You can do a shakel flip in the rear or just add blocks. you can keep the 2wd steering box and do a cross over steering , or swap to a 4x box. and then sorce a t case. This is the best rout IMO unless you hve a doner 4x4 that is all ready to go. Other wise even if you find a 4x4 frame and axles, you will need to add your lift, and go through the axles, and then still swap the body, engine, and tranny.
