Please help me!- wit's end.
I really hope somebody can help me out and point me in the right direction. I've got this 65 GMC. It's a piece of junk. But, I've been trying to successfully rebuild the 250 straight six in it. After taking everything but the shortblock apart and replacing or rebuilding it all, it was running okay other than a high idle and some off-idle hesitation. So, to fix the idle issues I replaced the carb with a remanufactured one, and now it has a really really (really!) wicked backfire out the exhaust (or after-firing, so I've heard). Now, I know that cherry bombs are known for that engine-braking pop, but this is retardedly stupid. I have the split headers collected into a pair of cherry bombs and that's it.
If I'm not WOT, it's backfiring. I'm talking fire-out-the- exhaust popping. If I try to maintain a constant speed, it backfires on what sounds like all cylinders until I either let off the gas or put it to the floor. I've tried to adjust the timing, adjust the air/fuel, and no difference. I picked up a timing light today, and when I hooked it up, the timing mark on the crank pulley wasn't even close to the metal tab with the marks on it. It's weird 'cause I've put a good thousand miles on it since the tear down with nothing like this prob, but as soon as I get the new carb, this starts. So you know, its a 250 Inline six with headers, HEI, and a single barrel carburetor. Any thoughts? ![]() Thanks so much guys!!
My 68 cougar restomod build:HERE |
![]() Join Date: Mar 2008
Re: Please help me!- wit's end.
I have no experience with inliners but on V8s sometimes people put the distributor in on the wrong marks, might that be the problem here? What about vacuum advance and the distributor itself? Are any of the plug wires maybe touching the block and have burnt through causing a short?
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it Last edited by 1964C10; 10-16-2009 at 01:27 PM. |
#3 | |
283 Drama Queen
![]() Join Date: Dec 2004
^2 (I have limited wit - so it doesn't take very long to get to the end of it.) Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
make sure that it sucking air at the base of the carb as you say it got worse after changing it. manifolds are not leaking? did you mix up any of your plug wires. distr out a tooth?
check your valve clearances and or bent pushrod ron |
Senior Car Nut
![]() Join Date: Jan 2008
sounds like somebody crossed the plug wires on you when you weren't looking. Seriously, if you didn't touch the distributor, just put the new carb on, and now its way off on timing, I gotta wonder. did it kickback big time when you first tried to start it? Distributor could have moved. Did you pull the cap to see if the rotor was broken? Also, I gotta ask, did you replace the cam and crank gears when you rebuilt the engine? Wait, (just re-read your post) I see you didn't redo the shortblock.
Larry Last edited by fleetsidelarry; 10-16-2009 at 04:35 PM. Reason: added comment |
283 Drama Queen
HA HA
#8 | |
![]() Join Date: Oct 2006
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Not an expert by any means, but I suggest you go back and start with the basics ( It can't hurt and it does't take that long). Verify that your cam and gears are set correctly at top dead center, then make sure your distributer shaft is set right. Then verify that your plug wires are in order. After that make sure you have no vacume leaks. If my Dad were alive that is what he would tell you to do (miss him every day).
Just last week a friend of mine had a small block chevy that he rebuilt under the close eye of a 30 year ASE certified mechanic, who I have complete confidence in, but it would'nt start. It never fired up, but he bent or broke all of the exhaust rods and bent all of the exhaust valves on a new pair of Edlebrock RPM heads. Turns out that it was not on TDC when they set the cam gears even though the cam and crank gears lined up "dot to dot". Goes back to what to daddy said "check and recheck EVERYTHING."
D's 63 |
For the kind of backfiring you say it's doing. I say it's the spark plug wiring or something that would cause the fuel to ignite at the wrong time. Hope you figure it out.
Check the distributor cap. When I was sixteen (circa 1976) I had a '70 Nova with a 230 six banger. Driving it home from work one day it began doing exactly what you are describing.
After my Dad cused me up one side and down the other for "blowing up the engine" my grandfather discovered it was a cracked distributor cap! ![]() Last edited by lakeroadster; 10-17-2009 at 08:35 AM. |
Okay, I finally got a chance to get into the truck again today. Please help me double check everything, because it's still not working-
So, with a backfiring engine, I: -Took out the plugs -Put my finger over #1 plug hole, turned fan until I could feel air blowing past my finger. -Took off cap- it was pointing almost at the #4 cylinder post (next to #1, counter clockwise) -I took out the distributor, moved it clockwise one gear-tooth, bolted it back in. This should make it point more at #1 post. Now it looks like this: ![]() -I put on the cap and spin it so the dist is pointed directly at #1 post: ![]() Then I wire it all back together in the firing order 1.5.3.6.2.4 ![]() -Here is what I don't get. In theory (right??) the mark on the crank pulley should be pointed right at the "0" mark on the timing plate thing. However, it is pointed about 90 degrees counter clockwise. Is this where my problem is? Timing mark- pointed up-left, towards water pump: ![]() Where it should be pointed at the timing mark plate? (what is this actually called?): ![]() With is set like this, it won't run. It will crank some, then crank forced/slowly like a too-retarded hot-start, but no starting. HOWEVER, if I turn the dist cap an inch or so clockwise, it runs just like it did- like crap. This is pretty much-over compensating for the one-tooth move in the distributor. The disagreeing timing marks is what's getting me. Thanks so much for continuing to follow this and help me out!! -click on thumbs for larger pic.
My 68 cougar restomod build:HERE Last edited by SeanPaintsFlames; 10-22-2009 at 05:57 PM. |
#13 |
You might want to check these sites for more info:
http://www.inliners.org http://www.stovebolt.com I think they will have more information on how to set this up right.
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
#14 |
All around good guy
Popping out the carb is a timing issue 90% of the time. Get the rig to top dead center and check your timing. Verify your timing order first. Sticking your finger over the hole isn't going to cut it. There is a compression and exhaust stroke. Do you know which one you were on when you checked it the first time? You can pull the valve cover and see which valve is down to verify.
bullington Last edited by bullington; 10-22-2009 at 07:43 PM. |
#15 |
Just because you feel air blowing pass you finger, doesn't mean the number 1 piston is all the way up......When you know it's on the compression stroke turn engine to top dead center...In other words get the piston all the way to the top.....Then drop distributor in.........
![]() Quote:
#16 |
Yep.
You must make sure #1 is top dead center on the compression stroke!! You will get some "air" on part of the exaust stroke, but timing wont be correct if you set the dist to #1 on the exaust stroke. SO make darn sure it is TDC on the compression stroke. Then set the dstributor and also take a look at that "timing mark thingy". Minor slippage/wear of the rubber bonding ring in the balancer - or the wrong timing tab thingy bolted on. Verify TDC! Then if the marks are not quite right remember that and adjust the distributor according. |
#17 |
![]() Join Date: May 2009
Hi 198+ if I read your 1st post correctly all was fine till you put a rebuilt carb on. Something got disturbed while changing out the carb. Either it's not adjusted right, a vacume leak, base gasket leaking. if all these are fine then it may be timing after it was fooled with or when was the HEI installed? The distributer could be 90* off have a qualified mech set it for you. There is another thing that will make the engine backfire, to thin off a gasket between the header and the head will make it leak and backfire, it could be just a crappy carb rebuild. Good luck---Vernski
#18 |
Have you done a compression check? Do you think maybe something fell in the intake when the carburator was changed? Maybe bent a valve? Was there more space between the intake and the base of the carburator on the old one? Sorry for the questions just thinking out loud. And the TDC as everyone has said must be on the money.
#19 |
![]() Join Date: Mar 2009
I bet you got a carb. with a bigger metering jet.
Did you keep the original carb? If you did, remove top of carb.'s to see the number stamp on the jets. If the numbers don't match,use the original jet in the remanufacture carb. See if it runs any better. Jimmy |
#20 |
Keep it simple.....
Put the timing back where it was & put the old carb back on. See if the perf returns to where it was. The carb might be rebuilt.... it might not be rebuilt correctly.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-25-2009 at 10:00 AM. |
#21 | |
Rust Buster
#22 |
Sounds to me like you have a flat spot on the cam
#23 |
Something else to consider, if you rev'd it real hard after you put the carb on it could have spun the outer ring on the balancer which will give you false timing readings no matter what you do. Don't even ask how i know this...
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
