Old 10-16-2009, 01:38 PM   #1
4oldcars
4oldcars's Avatar
Fuel filter
Haveing recently had a problem - - - I 'm told there is a fuel filter somewhere along the frame. I cannot find one on my sub. I think I've been running without a fuel filter. Does anyone know where this filter normally is located.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 10-16-2009, 04:07 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel filter
There shouldn't be one, and it's not a great idea to put one there either.
If your tank is clean, then the filter in the carb should be fine.
If your tank is dirty, then you should consider dropping it and letting a radiator shop clean it up.
If you have an aftermarket carb with no filter in the inlet, then an inline filter between the carb and the pump is the best place for the filter.
