Stock Heater box alternatives?
Does anyone know of a way to do away with the stock heater box under the hood On a 66 and move to a smaller one or a possible in dash one? I'm not sure if there are any options out there so i apologize if its a dumb question...
Thanks!
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck Last edited by oklahomaduner; 10-16-2009 at 04:20 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Stock Heater box alternatives?
One of my trucks has the stock under dash heater. It's called the "economy heater option" and it does not intrude into the engine compartment at all.
It just has two block off plates. ![]() ![]() ![]()
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 10-16-2009 at 04:35 PM. |
Do you know if anyone reproduces these or where i might be able to find one?
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck |
Clean set up. Do tell where you got it and the block off plates.
It's stock for my truck. This is what trucks got that didn't have the deluxe heater package.
Senior Enthusiast
I also have the stock economy heater in my 1960 GMC. I got mine on Ebay. I also see the block off plates there every once in a while.
Sunburst C10!!!
i got mine out of a 61 and put it in my 64
very simple and clean setup
Gage 1967 C10 Shortbed Stepside |
60-66 Nut
![]() ![]() Join Date: Mar 2007
If I'm not mistaken, those recirculating heaters were only available from '60-'63. They were intended for areas that don't get very cold,as they don't do the best job in very cold and damp conditions. I haven't seen them in the '64-'66's from the factory.
Here is a link to a couple of small heaters used for Hot Rods. About as basic and simple as it gets.
http://www.southernrods.com/categori...oduct-860.html http://www.southernrods.com/categori...oduct-867.html Last edited by lakeroadster; 10-20-2009 at 08:24 AM. |
I found some of the plates and heaters!!! haha
I bought mine from Old Air Products. Complete underdash heat and AC. It is somewhat expensive but not as bad as some of the other companys, works very well. I don't have any picks on my computer but it is pretty clean in appearance. It includes a block off plate for the old heater box as well.
Try looking in the 55-59 second series trucks. They have almost the exact same heater.
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
#13 |
I saw this on Extreme 4X4. I'm gonna grab one for my 65
http://www.summitracing.com/int/part...0002/overview/ |
