10-16-2009, 05:23 PM | #1 |
Air compressors??
what air compressors are you air bag guys using . the oasis is out of my reach but let me know what you guys are using? one or two and how big and who makes them thx oh pics to if ya got them
nickle and dime |
10-16-2009, 06:32 PM | #2 |
Happy to be here
Re: Air compressors??
For simple, cheap and reliable the Firestone (Thomas) compressors are hard to beat. If you want bigger, better, faster look at the ViAir units.
You don't really "need" two, but it's nice to know you have a back up in the event of a failure.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-16-2009 at 06:33 PM. |
10-16-2009, 06:34 PM | #3 |
AIRBAGPARTS.COM
I got two Viair 380s and two 3 gallon tanks.....
Works pretty well, but I may get another tank and/or a couple AZ compressors. |
10-16-2009, 06:37 PM | #4 |
Happy to be here
What's your fill time with two 380's. I have been considering adding another.
10-16-2009, 07:10 PM | #5 |
I Hate my 480c Viair, never any problems, but it and a 5gal tank just plain sucks lol. It's fill time is atleast 10mins. I'd add another but I'm going with an engine driven and be done. I have a 155psi switch and I want more play time and a faster fill and 155 isn't cutting it. I go two Viair 480's or a smaller tank for faster fills. My vote is Viair or Air Zenith.
10-16-2009, 09:19 PM | #6 |
i have to viair400 and two 3 gal tanks. fills in like 3 1/2 min or something real close at 150 psi . for a daily driver you cant beat having a dual setup incase one goes out becuase ive had that happen ..
10-16-2009, 09:51 PM | #7 |
York 210-can't beat it...endless switch play-seriously.
10-16-2009, 11:21 PM | #8 |
I have 2 viar 480's and 2-3 gal tanks w/ a 200 psi switch and I can lift the truck to ride height 3 times before they kick on, but i drive pretty low. This set up seems about perfect for normal usage. The oasis takes a ton of juice to run and probally isn't necessary unless you are gonna be playing with the switches a ton.
Josh Hart High Octane Hotrods 71 C10 Bagged work in progress driver Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912 Last edited by 5windowpickup; 10-16-2009 at 11:27 PM. |
10-17-2009, 01:03 AM | #9 |
One day.....
2 VIAIR 380 with 1 five gallon tank. No complaints.
DZL1 |
10-17-2009, 02:16 AM | #10 |
1 Viair 480 with a 5gal tank. Takes about 3 minutes to go from 110 to 145psi.
10-17-2009, 10:46 AM | #11 |
im gonna run nitrogen on mine with a back up tank and compressor for when i run out
10-19-2009, 08:28 AM | #12 |
E D York fast and quiet and probably cheaper than 2 or 3 elect.
some junk yards are full of them bob |
10-19-2009, 07:01 PM | #13 |
I gave $30 for my York at a swap meet, made my own bracket. A buddy of mine ran a york in his off road rig which was belt driven from an electric winch motor. It was all mounted on a wood board in the back of his Bronco, it worked great. Homemade Oasis basically for alot less money.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 10-19-2009 at 07:04 PM. |
10-19-2009, 07:44 PM | #14 |
low n' slo
i got a york too for my 5 gal tank, but since my truck doesnt even run i havent tried it lol. i bought an airlift 450c for now, i wonder how thats gonna hold up. when i get the york on im using the 450 for a backup and to run some airhorns i wanna get
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-19-2009, 11:08 PM | #15 |
Retiredoldfarttankerguy
So, time to weigh in with a likely silly question. Twin comps and dual bottles - are they plummed seperate. one forward one aft? or are they cross fed? Are you tying them with a valve that seperates them for an emergency cross-over?
________________________________ Swany Current 67-72 truck projo - #5 of 6 and #1,000,000... of all the other things that keep me from working on it. Fav - local parts shop. They ship world-wide. www.fillingstation.com |
10-20-2009, 10:07 AM | #16 |
It'd be alot cooler if you did
Most people tie them together. No need to complicate things.
10-20-2009, 10:11 AM | #17 |
AIRBAGPARTS.COM
FILL TIMES FROM
165psi-200psi 3 GAL 5 GAL 6 GAL 10 GAL Viair 380 2:19 3:51 X X 380 Combo 1:09 1:56 2:19 3:51 Viair 480 1:19 2:12 2:39 4:24 480 Combo 0:40 1:06 1:19 2:12 AZ OB2 0:48 1:19 1:35 2:39 |
10-20-2009, 10:12 AM | #18 |
AIRBAGPARTS.COM
Hopefully you guys can understand that. It came out all lined up when I did it in word. Sorry....
10-20-2009, 04:59 PM | #19 |
Thx guys. I think I will go with the 480c combo
nickle and dime |
10-20-2009, 10:43 PM | #20 |
GM ONLY BABY!!!
I have 2 Viair 480's off ebay and 2 5 gal. tanks, and 1/2" lines, no problems. Viair does warranty there stuff, tho.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
10-21-2009, 08:13 PM | #21 |
100% gearhead
I'm still running an Air Zenith OB1! had it for years but it has been rebuilt once. I am definitely a fan of AZ stuff. I also have a 5 gallon tank and the pressure switch is adjusted at 150 on, 200 off. Good recovery time. I also run nitrogen. I like to play. A lot. Next I am doing a york 210 and the AZ will find a new home in one of my other projects.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. Last edited by Imperial Kustom; 10-21-2009 at 08:16 PM. |
10-21-2009, 08:34 PM | #22 |
86 C10
I have a york 210 running 180psi and a 5 gal. tank your going to want to add another 5 gal and it would be perfect. oh and you dont need the 450 to run airhorns you could run them off the york.but yea keep the 450 for backup just in case i kept my electric for back up.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
10-21-2009, 09:18 PM | #23 |
2 viair 400c's. yet to fire them up.
