Damage Inc
Which oil pan for LS swap
Doing a ls motor swap on my 68 and since its bagged the regular truck oil pan hits the ground. I wanted to get a cts-v oil pan cause they are the smallest but are on national back order.
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
Re: Which oil pan for LS swap
Try ebay, thats where I found mine, you could also try posting a wtb add over at LS1 Tech http://www.ls1tech.com/forums/
Good luck! Last edited by short-t; 10-16-2009 at 09:31 PM. |
#3 | |
Damage Inc
I'm using an F-body oil pan for mine. My engine came with a corvette pan (definite no go) and the truck pan hung too low for my tastes
![]() Join Date: Apr 2005
What motor mounts are you using?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Trucks N Tranzams
I am going to use an F-body pan.
You might try these guys http://www.brphotrods.com/Cadillac%2...20engines.html or maybe this pan although it still may hang down to far. http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
Damage Inc
ordered the tubular ones from performance online and billet adapter plates from car shop inc.
The FBody pan should work with those mounts, but it won't work with the ECE mounts.
Damage Inc
for some reason its on back order at the dealer..to many ls swaps?
#10 | |
http://67-72chevytrucks.com/vboard/s...=272174&page=2
GM made with FORD paint
try a gto oil pan from 04-06
1972 GMC Custom 1500, 2WD LWB, 1970 chevy impala SS 350 c.i., shaved door handles, Ford Paint (portofino blue), blue underglow, and much more. 1998 GMC Sierra 1500 ext. cab, 2WD SWB, 305 c.i. all original 165,000 miles and still strong (daily driver) |
Trucks N Tranzams
Try this thread at the S10 forum. It shows all of the pans for LS engines. The GTO pan is a front sump pan and will not clear the crossmember.
http://www.s10forum.com/forum/f213/l...f-them-324366/
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" Last edited by Arad68; 10-18-2009 at 01:27 PM. |
#13 | |
The oddest Todd around
My Chevy dealership used to have all sorts of stuff I needed, but now it's like a ghost town in there.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
#14 |
69fatmotor
#15 |
![]() Join Date: May 2009
Will that one from GM Performance that's in the Jeg's catalog work??
#16 |
i have a 01 f body ls1 in my 70 with s&p motor plates the stock pan fits perfect.
#17 |
If the one from GM/Jegs will work with a DropMember than I will need to order one right up. That price is much better than others I have seen as well.
Kevin LFD Inc. |
#18 |
Damage Inc
i agree..you will be dragging a regular truck oil pan for sure
#19 |
69fatmotor
here's the measurement http://www.jegs.com/i/GM+Performance...12593/10002/-1 you'll have to scoll down in the window to see the measurements. the pan should fit about any installation.
#20 |
I picked up an F body oil pan. But what or whose motor mounts should I use??
#21 |
I built all my own mounts but I am cheap... plus I did this swap 3+ years ago before it was all the rage and there was not as much available. I am using a f-body pan, I had a truck on on but like you said it hung too low for my tastes. You will need the pickup tube and baffles for the correct pan.
good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#22 |
1967 C-10 SWB LS-6 T-56
![]() Join Date: Feb 2007
I have a F body one in my 67, fits good, but had to cut and tig a new lower face on the pan. Scaled a set of S&P mounts out of classic truck, and made a set out of 3/8 6061 aluminum. If you don't cut the pan, it may hit the passenger side of the front crossmember.
#23 |
If one wanted to run dry sump set up I have the Moroso pan, some of the lines and pump that came off an ASA LSx car. It is an incomplete set up but CHEAP.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
