Old 10-16-2009, 10:46 PM   #1
tim21391
tim21391's Avatar
402 to a 454 swap
ok i havent looked at the problems of my truck. i know something broke and its leaking oil faster then i can pour in... say i cracked the block.. if i get a 454 block.. can i use parts off my 402 if so what would they be? im building a 302 ford and stroking it to a 347 so ill know how to swap parts over
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 10-17-2009, 12:22 AM   #2
ripdog28
ripdog28's Avatar
Re: 402 to a 454 swap
You can use all of the brackts, mounts.... pretty much everything but the internals.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 10-17-2009, 02:02 AM   #3
tim21391
tim21391's Avatar
oh ok thanks
Old 10-17-2009, 02:07 AM   #4
68 50th
68 50th's Avatar
I did the same swap and I used, heads, valve covers, intake manifold, carb, exhaust manifolds and all brackets and pulleys. You can not use the flywheel and balancer. Mine was a 72 402 to a 73 454 swap.
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 10-17-2009, 02:23 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that is correct, eerything but the ballancer and flexplate/flywheel.
If your 402 carb is perfectly tuned, then it'll need some messing with for the added 50 cubes, but it's still do-able.
