Old 10-16-2009, 11:44 PM   #1
1966chevroletpu
1966chevroletpu's Avatar
back-firing problems
hey guys i haven't been on here for a while, but im still working on my truck and still a project. Anyways i have this problem when i punch on the gas sometimes or every once in a while it back fires once and sometimes it bogs. I just fixed the timing and when i did the timing, i put the #1 piston up to TDC mark and everything set right and still does the same thing. if anyone can help that would be cool thanks....
1966chevroletpu is offline   Reply With Quote
Old 10-17-2009, 12:26 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: back-firing problems
I would adjust or check your accelorator pump. Sounds like it needs to apply some more fuel along with the air when you stomp on it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-17-2009, 01:01 AM   #3
1966chevroletpu
yea because it does that only when i got to punch it, i thought it might need a rebuild, Cuz i had the carburator for three years now and i don't know when was the last time it was rebuilt
