10-17-2009, 01:59 PM | #1 |
newer frames
I have an '85 short box with a badly rusted frame (western NY) and I'm having trouble finding a good replacement frame. Does anyone know how close the '88 and up frames match up. They are still plentiful in the junkyards here.
Thanks. |
10-17-2009, 02:19 PM | #2 |
Re: newer frames
I've seen it done but it's not a bolt up affair. Looked like they had to build all new body mount points. It was a 4x4 so they built a little bit of body lift into the mounts they made.
1977 GMC Sierra Grande |
10-17-2009, 06:33 PM | #3 |
Re: newer frames
Yeah, rust free parts are almost impossible to find in this neck of the woods. I'm in Fredonia..not too far from you. All the good stuff has to be "imported" from down south or out west. Good luck finding what you need. Lookin for 2WD or 4WD?
10-17-2009, 10:17 PM | #4 |
Re: newer frames
yeah, this is what they call "God's country". I'v found a couple of long wheel base frames but i'm debating the work involved in making a long wheel base in to a short wheel base compared to makng a '88 & up short wb fit. Looking for 2wheel drive. 4WD would actually be easier to work with.
10-17-2009, 10:59 PM | #5 |
Robert Olson Transport
Re: newer frames
there are quite a few pick and pulls in PA that have the swb frames in decent shape for our area
10-18-2009, 10:12 PM | #6 |
Re: newer frames
To be honest, if you can weld (or know of a good welder), it would be easier to shorten a lwb frame. The reason I say that, is the 88-up frames are wider and different in wheelbase, so you are gonna have to lengthen/shorten anyway... plus build new body mount locations, because they aren't even close.
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels Who needs a car when they make crew cab trucks? |
