Steel wheel help please
Are there any specific common years and vehicle types to ask the junk yard for on the 15x7 6 lug steel rims that will fit my 67 truck?
I have 225/75R15 rubber that I want to put on them and they seem to fit well on the 7 inch wide rims I have now, so I figure that I should stay with 7in wide wheel.
Mark 1967 C/10 stepside lwb daily driver 1968 C/10 fleetside lwb parts truck 1971 Cheyenne Super swb project |
Re: Steel wheel help please
Ok I am still a little unsure what years I can pull from. I just got a hold of two 15x8 6 lug 10 hole rallys, will these fit my 6 lug 67? If so what years did these wheels come from so I can search my local yards for two more. Thanks.
67-72 parts collector,…
![]() Join Date: Nov 2002
Yes they will.
They were found on Chevy/GMC full size 4x4 trucks from 73-87.
![]() Join Date: Jul 2009
Do you still have drum brakes on the front?
Yes will they still work?
yes
Perfect! I've already ground down those rivets from a past brake job. Thanks a ton for your info guys.
Could you do me a favor and take a pic of your 225s on your 7" rims. I am about to put 5 lug 7" rallies on my truck and would like to see what the tire looks like. Thanks
This is my 69 stepside with 245/60R/15 on the front and 255/60R/15 on the rear. I have a 2 inch drop and will probably go with 265/70R/15 when the time comes for new ones. I think they will fill the wheel well better
Ok got the pics. the ones on the front are the 225/75/15 the rears are 235/75/15.
Fronts
rears
#13 |
Not much of a difference between the two.
#14 |
I forgot I had one of the side
#15 |
I like that set up, looks good, do you have any pics from the rear to see the width of the tires?
#16 |
I wouldn't mind going wider on the rear, but I will stay with the height I am running to keep a tad more ground clearance. My truck sees a lot of trips down to the river and it has a few dips that I barely clear as of now.
