Old 10-17-2009, 04:44 PM   #1
osaltyone
osaltyone's Avatar
question on bagged front end
Do you guys have to air up the front end quite a bit to clear the fender wells on a turn? I have the Cool ride kit up front and yesterday was the first day I drove it in 3 months (took a while to get everything installed) and I had to jack the front end up to 110psi to clear 20's.
osaltyone is offline   Reply With Quote
Old 10-17-2009, 10:52 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: question on bagged front end
Tell us more about your set up. What year truck, what size 20's, dropped spindles, etc.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-18-2009, 03:54 AM   #3
osaltyone
osaltyone's Avatar
It is an 84 with belltech drop spindles and the full cool ride front suspension upper and lower strong arms, their bags and shocks. The rims are Helo Skids with 275/45/20. And I belive they are 20x9.
Old 10-18-2009, 06:13 AM   #4
OARNGESI
OARNGESI's Avatar
Your front tire is almost 30 inches you may need a smaller front tire
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-18-2009, 07:44 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Got any pics?
That 110psi is also raising the weight of the engine.
I have Slam Specialties RE-7 bags on the front of my blazer. I ususally have to air up to about 100 psi just to get the front up high enough,... but then I drive it at a lower pressure. (80 psi).
I have 245/40-20's up front.
Keith
Convert to disc brakes.
Old 10-18-2009, 09:35 AM   #6
SCOTI
SCOTI's Avatar
Yep, that tire size would be why you're having to crank the pressure up so much for turning. A 245-40 (27.7" tall) would be max height & still be able to turn lock-to-lock w/o interference @ 'ride' type pressure.
I put 255-40's on my static dropped 74 (3" spindles, 1-coil cut) & I could barely move down the road as it was constantly buzzing the tops of the inner fenderwells. They're 28" tall. If you're set on that rolling stock combo & size, you're going to need to do some inner fenderwell surgery.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-18-2009, 10:37 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
For point of referrence I have the same set up on my 77 with a 245/40/20. I can cruise at 65 psi and ride at 80-84 psi.
Articles-
"Refining Sierra"
Old 10-19-2009, 12:02 AM   #8
osaltyone
osaltyone's Avatar
Thanks! I thought the tires might have been a bit big when I got the rims and tires. They were used and a steal with tires for 250. I will just have to save up for lower profile tires later on.
